LibreCAD for Building Survey projects
25 messages Options
12
Re: LibreCAD for Building Survey projects
Tim Payne
Hi again dellus,
I have created the floor plan at 50 (current drawing preferences) so that the dimensions (5 mm figures & arrow heads) are legible at life size.
I increased this to 1 in General Scale in Drawing preferences, dimension details shrink to nothing
imported the A2 Drawing Template (1:50) and increased (modify scale) this by 50 to make it 1:1
Then... I selected the floor plan and positioned it within the Drawing template, then made the General Scale 50, so the dimensions became legible.
Selected print to pdf, but largest paper size is A3, so couldn't get the full drawing, but that is a limitation I will have to live with, I guess.
Thanks very much for your advice.
BR
Tim Payne.
Tim Payne
Largest papersize A3? You can print at any size, also export to pdf.
Tim Payne
These are the options (Print to PDF or XPS Document Printer) when I select: PDF; Print; Preferences; Advanced; Paper/Output - A3 being last option at the top of the drop down list - have I missed something?
Tim Payne
Hi dellus,
I see now - I have now exported the drawing to PDF via File; Export; Export as PDF - A2 size, much obliged, sorry I've been such hard work...
BR
Tim.
12
