Hello all,
Development is very busy now with tremendous new features that will be unveiled in LibreCAD 2. Check out what's going on at github and IRC to get a preview. I've been periodically watching the progress to make sure everything stays within license compliance. Some issues we should resolve: 1) what is the license and copyright for jwwlib/? "dl_jww-copy.cpp" says "Copyright (C) 2001-2003 RibbonSoft. All rights reserved." and licensed GPLv2, but I can't find that file from anything RibbonSoft distributes. The other files are not licensed at all. Could we check into the copyright and license for that library (make it GPL2+ i.e. GPLv2 or greater)? If we're not planning on releasing this ever (if the new dxf library doesn't need it, for example), they we don't have to worry about it. 2) I already talked to Rallaz, but ttf2llf has the same problem (it says copyright RibbonSoft, but I don't see anything at RibbonSoft's site about it; and the license is only GPLv2 not GPLv2+) Cheers, Scott |
Hi Scott,
I just added to repository the following licenses: GPLv3 and Apache2 because the newly added WenQuanYi fonts are covered by Apache2 or GPLv3. Thanks Dongxu
On Mon, Dec 5, 2011 at 10:00 PM, showard314 [via LibreCAD] <[hidden email]> wrote: Hello all, -- Dongxu Li, Ph.D. |
In reply to this post by maqifrnswa
> On Dec 5, 2011, at 10:00 PM, showard314 [via LibreCAD] wrote:
> I've been periodically watching the progress to make sure everything > stays within license compliance. Some issues we should resolve: Thanks everyone. I'm trying to keep the LICENSE file up to date with everything we have. This will make it easier for release and eventually for upgrading licenses. If you see anything wrong with LICENSE, please update it or correct it too. Cheers, Scott |
inverse response:
2) the utility program ttf2lff is a modification of ttf2cfx: http://www.qcad.org/rsforum/viewtopic.php?t=415 some parts have my copyright, but unmodified parts have copyright from RS. Is posible to mix licenses in one sorce file? like: ** code from Rallaz license GPLv2 or greater ** code from RibbonSoft license GPLv2 1) the jwwlib files do not have any license and copyright, except: dl_jww.h -> based in dl_dxf.h from dxflib dl_jww.cpp -> based in dl_dxf.cpp from dxflib original repository: http://en.sourceforge.jp/cvs/view/jw-qcad/cad-qt4/jwwlib/src/ Rallaz |
On Wed, Dec 7, 2011 at 12:01 PM, Rallaz [via LibreCAD]
<[hidden email]> wrote: > inverse response: > > 2) the utility program ttf2lff is a modification of ttf2cfx: > http://www.qcad.org/rsforum/viewtopic.php?t=415 > some parts have my copyright, but unmodified parts have copyright from RS. > > Is posible to mix licenses in one sorce file? like: > ** code from Rallaz license GPLv2 or greater > ** code from RibbonSoft license GPLv2 It is possible to mix licenses, but until all the original code is removed it is GPLv2 only. Mix licenses allows for future upgrading or changing over to new licenses while maintaining compliance in the short-term. > 1) the jwwlib files do not have any license and copyright, except: > dl_jww.h -> based in dl_dxf.h from dxflib > dl_jww.cpp -> based in dl_dxf.cpp from dxflib > original repository: > http://en.sourceforge.jp/cvs/view/jw-qcad/cad-qt4/jwwlib/src/ If it's based on dxflib, it should have at least the same license as dxflib (since it is GPL.) It would be better to add the correct license information and copyright information. I'd be comfortable saying it is GPLv2-only since it is a derived work from dxflib. Thank you. ~Scott |
