LibreCAD on Mac - Keyboard Command Aliases
6 messages Options Options
piper
I modified librecad.alias in the Mac Library under Application Support and saved the file, but restarted LibreCAD 2.0.7 on OSX 10.9.5 is not recognizing the command. I'm a newbie to LibreCAD and I've searched how to do this.
Any suggestions?
Re: LibreCAD on Mac - Keyboard Command Aliases
Please upgrade to 2.0.8
remove the old alias file before you upgrade.
If 2.0.8 still doesn't work for you, please upload and share your alias file.
Any suggestions?
piper
Followed instructions but same thing is happening.
Added 'Zoom' and 'Copy' at end of file.
#LibreCAD alias v1
# lines starting with # are comments
# format are:
# alias<\t>command-untranslated
rect rectangle
xt xt
re re
pa parallel
rg regen
tm tm
rh rh
tn tn
ch fillet
rm xt
ci circle
rn rn
ro ro
er er
pl polyline
rr rr
ld ld
po point
rv rv
li line
np np
rz setrelativezero
a ar
sa sa
sc sc
sd sd
rec rectangle
da da
se se
sf sf
sg sg
k kill
l line
si si
dh dh
o parallel
sm sm
sn np
r r
uu r
u undo
ss ss
dr dr
mi mi
oo undo
sz sz
dv dv
div cut
os sf
rectang rectangle
zr regen
mv mv
xp xp
z zoom
c copy
zoom and copy are not commands.
http://wiki.librecad.org/index.php/Commands
mv for move/copy
or
- select an object
- press ctrl+c
- select a reference point
- press ctrl+v
What do you want to happen with the zoom?
We have:
- scrolling the mouse wheel
- ctrl & - / ctrl & +
- view → window zoom
piper
Ah, OK, thanks. I'm coming from an AutoCAD environment (PGP file), so I figured commands would work similarly. Zoom Window, Zoom Previous, Zoom Extents and Copy I tend to use a lot, so one keystroke+Enter works pretty fast.
Related tip: double click the middle mouse button (usually scroll wheel) to "Auto Zoom".
