LibreCad dies when create polyline from entities
8 messages Options
eingram
I was trying to figure out how to make four lines that were in the form of a rectangle joined as one unit.
I was trying the create polyline from esisting segments. I had four lines selected when the program crashed. If smeone will show how, I will attach screen shot.
Re: LibreCad dies when create polyline from entities
Draw four lines like a rectangle
"draw->polyline->create polyline from esisting segments"
select one line, result:
the four lines are changed by a closed polyline and no crash.
Wath is your system and LibreCAD version?
You can attach a screenshot and, more important, the file to reproduce crash?
eingram
Librecad version 2.0.0beta1
Win 7 pro 64 bit
I still don't see how to attach screenshot or file.
In mail-list mode attach the file.
In forum mode, see this screenshot:
RE: LibreCad dies when create polyline from entities
eingram
As you can see, in forum mode it doesn't offer me the option of an attachment.
In mail mode, I was trying out a new service called outlook.com and they had no provision for attachments.
I have switched my outlook.com format back to hotmail format and now I can attch.
Still can't attach in forum mode, though, thanks.
Edward E. Ingram
Date: Wed, 26 Dec 2012 23:33:26 -0800
To: [hidden email]
Subject: Re: LibreCad dies when create polyline from entities
http://forum.librecad.org/LibreCad-dies-when-create-polyline-from-entities-tp5707345p5707358.html
To unsubscribe from LibreCad dies when create polyline from entities, click here.
Aghhh!!! wrong "More" menu. :D
In thread, first click in "Reply", write response, then click in "More->Upload a file",
then continue writing response, if you want, of course.
eingram
Chair.dxf
I guess my question is: "is it possible to turn a rectangle into a single entity?" (so it can be copied, replicated, moved rotated, etc.)
To turn 4 lines in a sigle entity (polyline) is required
Attached your file with all lines converted as polylines:
Chair2.dxf
About your crash, I can't reproduce in winXP 32bits
to find a solution.
Please follow these steps:
"Start->Run" cmd.exe
cd "directory"\"with"\"draw" (like c:\Documents\MyDrawings)
c:\ProgramFiles(x86)\LibreCAD\LibreCAD.exe --debug chair.dxf 2> out.err
The previous steps open LibreCAD and load chair.dxf, then select
"draw->polyline->create polyline from esisting segments" to produce the crash
Find in "directory"\"with"\"draw" a file called "out.err" and attach it (compresed)
