Line(s) using relative coordinates
TonyDE
I am trying to use the line command using relative coordinates. Everytime I input  a line that measures 1'-5 5/16"<0 it always comes back with "Expression Syntax Error." I use to use autocad and never had problems using relative coordinates. I always assumed that no matter the cad software you use using relative or polar coordinates is the same in whatever cad software you're using. Am I wrong assuming that???
Tony
Re: Line(s) using relative coordinates
Hi tony,
Currently, there is no support for 1'5" type of input yet. We had some proposals on this particular feature.
An alternative could be ( 12 -(5 + 5/16))<0
Tony
TonyDE
The equation ( 12 -(5 + 5/16))<0 does not come out to "1'-5 5/16". The actual distance is 0'-6 7/16". Can you give me the correct equation??? Sure would appreciate it.
I'm lost on the meaning of 1'-5 5/16 or 0'-6 7/16"
rolgiati
On Tue, 24 Nov 2015 07:54:35 -0700 (MST)
Serves you right for faffing around with your outdated Imperial, and not using metric...  ;-3)
Cheers,
Ron.
           All that is necessary for the forces of evil to triumph
                    is for enough good men to do nothing.
                                                   -- Edmund Burke
Mike Hayes
Hi Tony
I'm guessing that you're using the - sign as a separator between the feet and inches and not in the mathematical sense as the subtraction symbol.
If so, the correct equation would be ( 12 +(5 + 5/16))<0
Mike
