Make a line with a angle relative to another line
8 messages Options
hesediel
Hello guys, i'm sorry for the question but i am trying to draw a line with an angle but this relative to another line. How can i do that?
Re: Make a line with a angle relative to another line
You can use modify → rotate
and choose to keep the original, or make copies.
In reply to this post by hesediel
There is also line → relative angle
it's a good thing if we can have angular "Relative Zero".
seems to be easy to implement:
1, relative zero for input polar coordinates;
2, relative zero for output (coordinate widget);
3, an action to change angular relative zero.
Before that, we can do the following:
To draw a line by an angle relative to to line A:
1, rotate line A to horizontal, keep the old copy;
2, draw a line by angle;
3, rotate the new line from step 2 and line A back, delete old copy;
4, delete duplicated copy of line A.
hesediel
i tryied the angle relative but its complicated, puts the line in the middle and several times isnt at the lenght i wrte.
the rotate it can work, but then how can i resize the rotated new line at a wanted lenght?
you can always use "Modify -> Scale"
using one end point as reference, and isotropic scaling.
Another feature not so difficult to implement:
when command widget is activated, *i.e.* user is typing a command:
1, figure out the command is waiting for coordinates (the default), supply coordinates as candidate for command;
2, if user is waiting for angle supply the angle relative to the current relative zero;
even easier to implement, create special variables for command line:
"xy/cartesian"
"theta"
for example.
abi12
Hop; you can respond to a different question.  My Selection does not work.  Only on 'Angle BETWEEN lines'.  What shall I do?  thanks!   gripwin@gmail.com
