Maybe a dumb question: for arc tangential to a line, don’t you need radius and degrees?
mikepwagner
I hope that this is not a dumb question - maybe I don’t understand the geometry?
I have been reading the documentation for “Arc Tangential”, and the documentation says that the command takes either a radius or a number of degrees.
Don’t I need both?
Couldn’t I have a 15 degree arc of radius 36” tangential to a line, and also have a 35 degree arc of radius 16 degrees tangential to the same line?
Re: Maybe a dumb question: for arc tangential to a line, don’t you need radius and degrees?
Just try out the feature. In the Tools Options bar above the drawing area you are asked for either a radius or an angle, additionally you are asked in the command line to specify an end angle or an endpoint respectively.
