Hello boukyaku,
On 02/08/12 11:55 PM, boukyaku [via LibreCAD] wrote:
> I am currently using LibreCAD 1.0.1 on Ubuntu 12.04.
> I was wondering if there was a way to mirror TEXT in this program. I
> don't want to explode the TEXT as that would convert it into lines
> and
> arcs which will make the file useless with what I use it for. When I
> try
> to mirror text it mirrors the box but does not flip the TEXT. You can
> currently do this with AutoCAD 2012 but you need to change some
> mirroring options specificity for TEXT.
- I think you talk about the AutoCAD "True text mirror" option.
If this is really this option you talk about, I think that LibreCAD
do not support "True text mirror", but only "Readable text mirror"
mode.
- I you want, you can fill a feature request, using the link below:
http://sourceforge.net/tracker/?group_id=342582&atid=1433847 >
> Is there a way to insert a TEXT entity and not MTEXT? I have to
> convert
> MTEXT to TEXT using AutoCAD 2012 which is the only reason why I am
> forced to use that program :p.
- LibreCAD V1.x do not support "TEXT" entities, but only "MTEXT"
entities.
- There is work in progress, implementing "TEXT" entity support on
LibreCAD 2.0 (upcoming version), but I do not know the status of
that work.
Claude
