There's a new "Widgets" top level menu.
When expanded, there's "Dock Widgets".
Now, you can choose Layer Tree, or "re-dock Widgets" later on.
Alternatively, you may try the menu or toolbar Creators under Widgets to for customized menu or toolbars.
Bron_Zero wrote
Thanks, dellus, for the replay. I saw this possible solution on another post where a guy had one layer missing from his drawing, so I had already tried this before I made this post. Unfortunately, it didn't change anything. My situation is quite different though. This other person had his work disappear that was on a certain layer. I can see all the layers on previous drawings, but the actual "Layer" menu is not there at the top where "file", "edit", "view", (etc.) drop down menus are. I'm thinking if I can do a completely clean uninstall and reinstall, it may clear it up, but I'm not sure how to do that.
