No puedo Abrir Archivos
maxmonzon
imagen libre cad
Re: No puedo Abrir Archivos
maxmonzon
Estimados , tengo LibreCAD corriendo sobre Linux mint 19.3 y este es el mensaje quie me aparece , alguna idea como resolver el inconbeniente . Gracias
perepujal
In reply to this post by maxmonzon
Hola,
DWG support is not fully supported in LibreCAD.
If LC can't fully open the DWG, then it will throw the message you saw.
Your best bet is to ask for a dxf to the person who provided you the
dwg, or relay on some dwg to dxf converter out there.
That said, IF you are able to compile LC and IF you assume to lose some
of the data in the DWG and IF you are lucky, you could modify the code
that checks for errors in a DWG and let LC try to open it anyway.
From my experience this helps in about 20% of DWGs that pose problems,
at the cost of losing some unrecognized entities and lose some format,
the other DWGs are plainly unopenable with LC
