Objects taken apart when imported as blocks in draft mode
Daniel84
Hi All,
Does anybody have any idea why sometimes when importing and object made of different blocks the object then get dismantled?
Pictures below for reference.
Re: Objects taken apart when imported as blocks in draft mode
Daniel84
So far I have solved the problem by not creating a block made of more blocks, but simply to import each block directly into the main drawing.
I wonder if this is a bug or a normal behaviour of the program.
Love LibreCad so far, it's making my project come to life with an amazing precision and it's also giving me the chance to revise and test on structural errors and mistakes in project phase.
This probably is a bug.
Can you share the distorted block source file?
That would make debugging easier.
Daniel84
Hi Armin,
Thanks for your reaction
Unfortunately I am not able to provide you said file. Since I am working on different projects I have quite a few files in my folder, I try to keep them non redundant, which means that whenever something doesn't work the way I want it to I just rectify the problem and get rid of the obsolete files immediately.
Otherwise I will start get too many unused files which I forget about turning my projects into a mess.
Any other way I can help you with this ?
