Offset distance
Offset distance
Bryon
Hi.
Using 2.2 version.
Trying to change the default offset distance. Following the manual's direction doesn't work. Using polar coordinates or simply setting a new distance using arrow bracketing changes nothing. The distance remains the same.
Any thoughts are welcome.
Bryon
Re: Offset distance
Why do you post this in the developers section?
The default offset distance is the one used last time.
A new distance is set in the Tool Options bar above the drawing area. True, this is missing to be explained in the manual.
Re: Offset distance
Bryon
All due respect the last used offset difference does not post "correctly". Using 2.2and it's actually posting a distance used 3-4 times previously and that's every time I check it.
Re: Offset distance
Sorry, but then I don't know a solution for you. It works correctly for me.
Something could be wrong with your installation, or you just don't understand something of the handling, but I have no clue what it could be.
