PDF import
11 messages Options
PDF import
Dimi
Hi there,
I use this LibreCAD version:
portable LibreCAD
It's a very cool tool.
My drawing cannot see the imported PDF background, although I can see its frame in the DRAFT option. Yesterday, when I closed the drawing, everything was visible.
However, I can still import photos, e.g. converted from PDF, but their quality is to poor for my work.
I am waiting for quick help, please.
Re: PDF import
rolgiati
On Thu, 30 Jan 2020 04:35:21 -0700 (MST)
> was visible.
Use the highest definition available on one of the pdf2gif or pdf2jpg free conversion web pages, and use the resulting image.
For instance https://pdf2jpg.net/ (free plug from a contented user  ;-3)
Cheers,
Ron.
                    Which is worse: ignorance or apathy ?
                           Who knows ? Who cares ?
Re: PDF import
Dimi
Thanks Ron,
Does this mean LibreCAd does not import PDF ?
Laud to Scotland
Re: PDF import
You say you have imported a pdf, it didn't show, but you could see the frame in draft mode. I can't even see the frame. No, LibreCAD can't import a pdf.
I just have tried to open a pdf in Inkscape and then save it as dxf. Worked surprisingly well. But contained bitmaps were lost.
Re: PDF import
Dimi
In the screenshot can see PDF frames but cannot see its contents:
Re: PDF import
rolgiati
In reply to this post by Dimi
On Thu, 30 Jan 2020 05:39:09 -0700 (MST)
dont think so.
Cheers,
Ron.
                  Where questions of religion are concerned,
                 people are guilty of every possible sort of
                   dishonesty and intellectual misdemeanor.
                                            -- Sigmund Freud
Re: PDF import
OK, yes now I see, if you import a pdf as an image, you get a frame visible in draft mode. It's allways a square of 1x1 units size (with standard import settings) regardless of size and content of the pdf. So it's nonsense.
Re: PDF import
Dimi
Thanks guys, but I'm at the starting point.
Either I can't handle LC or the image import interface should automatically limit the type of files to import.
PDF is a very popular image standard, so if LC does not import PDF, it needs some extension corrections and maybe someone smarter will solve this problem.
Re: PDF import
File, Import, Insert Image, Filename: All Image Files - No pdf. Seems clear.
pdf is not a format, it is more a binder for other formats. (Note svg, a vector format, is also in the list.) Write an extension if you feel you need one.
Re: PDF import
If you import a svg via Insert Image, it is imported as a bitmap image only, even if it originally is a vector drawing.
Re: PDF import
wjflier
FYI,  use online PDF to DXF converters.
