Parallel command ?
7 messages Options Options
Parallel command ?
yori5070
I hope in the resurrection of command.
Lines > Parallel
Re: Parallel command ?
All the parallel tools are modify → offset.
In reply to this post by yori5070
That's the command: o
yori5070
offset_command is inefficient.
Therefore, I hope in the resurrection of Parallel_command.
In 2.0, there are "parallel line (by distance)" and "Parallel line through point". At least we should provide both features.
@yori
In what way is it inefficient?
It's the same tool.
You can't get any more efficient than typing a single letter.
You will find the parallel line tool restored in the next nightly build.
