Parts Library
10 messages Options
Parts Library
zs1otb
Hi I'm from South Africa and I am busy compiling a set of "icons" for architectural use in construction. This entails the drawing of various windows, doors, sanitary ware etc. which are used in this country.
How do I go about to save these designs in the Parts Library of LibreCAD? Do I only need to save the .dfx file or must a .png file also be created?
As a matter of fact, where is the Library stored on a Linux (Ubuntu) installation. Is it in the usr/share/... folder.
Can I save this in the home/~/.local folder so that LibreCAD can access this?
Asking a question is not stupid, it is rather a sure way to get enlightened...
Re: Parts Library
Create in your home  a folder called ~/myCadLibrary p.e. and
 ~/myCadLibrary/bath
 ~/myCadLibrary/bedroom
 ~/myCadLibrary/others
etc.
add in each folder the corresponding dxf files
in LibreCAD go to menu "Edit->Application Preferences..."
in the oppened dialog select tab "Paths"
in "Part libraries" add /home/"user_name"/myCadLibrary (~/myCadLibrary not work)
close LibreCAD and reopen it then ready!!
Note: you can add more paths separated with ";"
Re: Parts Library
zs1otb
Rallaz,
You have made my life so much easier. Wow this is so simple yet so effective.
Thanks once again.
Re: Parts Library
MikeH
Rallaz,
doing as you suggest I simply can not see the library, nor the *.dxf files in it. All I see in the library browser are the directories "misc" and "templates", which were automatically installed in "/usr/share/librecad/library" when I installed librecad.
Any further ideas?
Greets
Mike
Re: Parts Library
MikeH,
You have added the paths in "Edit->Application Preferences..." ?
If yes, please, comment about your system and LibreCAD version
Re: Parts Library
ttaa
In reply to this post by MikeH
Hello!
I suppose you have solved your problem since you are quiet?
Your problem may be that you are missing the directorys that are mentioned above (bath, bedroom and others)?
BR!
Re: Parts Library
pommy69
In reply to this post by zs1otb
hi can you help im looking for construction libary, like power points and so on.  Can you help as im new to this . thanks
Re: Parts Library
glad that you found the right place for your question.
With pleasure I asked Google for you:
https://www.google.com/search?q=librecad+electrical+library
The first hit already contains two electric libraries.
When they are not sufficient for your need, you may find more here:
https://github.com/LibreCAD/LibreCAD/tree/master/librecad/support/library
How to use the libraries is explained in the manual at https://librecad.readthedocs.io/
or our wiki at https://dokuwiki.librecad.org/
and I suspect that there is more than one thread here in the forum, all sites have search function too.
You may also find tutorials on YouTube.
At least, when the libraries don't have what you need, you can create your own blocks and library.
Re: Parts Library
Gary S
In reply to this post by pommy69
Here is another source for architectural blocks: https://github.com/GSStnb/dxfBlocks
Re: Parts Library
Snapafun
No longer under "Edit" - Try "Options"
