Print Preview Shows Lines Thicker
jsb.clc
I searched the forum and was unable to find a topic relating exactly to mine. Thank you in advance.
All the lines are drawn to 0.0mm and continuous. The majority of the lines are much thicker, while a few are the size I would like them to be. All of this is in Print Preview. I have below a screenshot for you guys. How do I make the thicker lines thinner?
Printer Preview Image
Re: Print Preview Shows Lines Thicker
Are really all lines drawn with 0.00 mm? Have you drawn it yourself? Best you provide the file here.
You can change line properties with Modify - Properties (single entity) or -Attributes (multiple entities).
Might also be an issue of layer properties.
jsb.clc
Dellus you're a genius. That worked perfectly. Even though all my layers are at 0.0mm, somehow some were changed to 2.00mm. Still puzzled as to how though. I created this file from scratch by myself... Thank you very much!!!!!
