Printer Settings
12 messages Options
Printer Settings
claytoncarney
Every time I print, this pops up:
Don't understand. Drawing and Printer dimensions are exactly the same. Does not matter whether I chose Yes or No. This dialog appears every time I print.
What's wrong here?
Re: Printer Settings
This was fixed in 2.2.1_rc and later.
What's wrong here?
claytoncarney
Version: 2.2.1_rc3-5-gb2214827
Compiler: GNU GCC 12.2.0
Compiled on: Jul 18 2024
Qt Version: 5.15.2
Boost Version: 1.75.0
Still doesn't seem to work as expected...
Sorry, I was mistaking. The fix was in 2.2.2, not 2.2.1_rc
I have backported the fix to 2.2.1_rc, so 2.2.1_rc3-7 should have the fix
Qt Version: 5.15.2
claytoncarney
Version: 2.2.0.2
Compiler: GNU GCC 13.1.0
Compiled on: Jul 29 2023
Qt Version: 5.12.11
System: Windows 10 (10.0)
Perhaps I'm doing something wrong, but this is still displayed every time:
The first time after selecting Yes, the Drawing settings size was only 4 decimal places. Manually changed to 5 places, but issue persists.
The only obvious difference is Custom vs Letter. The size in the Printer settings don't make sense for standard Letter paper.
The fix is now in 2.2.1_rc, but the version number you supplied is 2.2.0.2
claytoncarney wrote
Version: 2.2.0.2
Qt Version: 5.12.11
claytoncarney
Apologies. Clicked the wrong version.
Version: 2.2.1_rc3-7-g29edbf9b
Compiled on: Jul 20 2024
Qt Version: 5.15.2
Still the same results as previously reported. Don't understand where those strange printer settings are coming from.
Could you share a drawing to show this issue?
Just in case, are you specifying the dpi?
Qt Version: 5.15.2
claytoncarney
1811_solano_inch.dxf
I am not aware of a way to specify dpi.
Thanks a lot for your testing. It's indeed a bug in our previous fix.
A new fix is now in 2.2.2-alpha and 2.2.1_rc3-8
claytoncarney
Version: 2.2.1_rc3-8-ga1a16168
Compiled on: Jul 21 2024
Qt Version: 5.15.2
Unfortunately, still...
Again, the only difference appears to be the name of the size.
claytoncarney
rc3-8 regression...
Now the scale (print preview tools options) keeps changing, even though fixed is checked. This was not happening in 2.2.0.2.
