Printer configuration
Rahooty
I have read posts here with people not being able to print,  some have cobbled work around to get something,  anything, over the believe it or not "years".
I like this program better than even some of the paid for programs.  But this is a requirement.  What good is a dwg/dxf if it cannot be printed or exported properly.
I have spent days on this.
It appears when changing the print margins it is changing the paper size and not the image size to fit in the margins. Selecting "shrink to fit" does nothing.
I had the same problem every one else had with the lines (in fact the entire page) was so light you could barely see it. I changed the lines thickness and it helped but still to light,  so in the advanced settings I changing from "graphics" to "Black and White" and the lines printed perfectly.
Then changed back to "Graphics" and it printed perfectly?????
This shouldn't be so limited on configuration with such a wide variety of printers out there
Re: Printer configuration
Thank you for the feedback on printing. Do you suggest any changes to https://docs.librecad.org/en/latest/guides/completion.html?
