Printing Issue
Printing Issue
rdorsch
I am trying to print part of a dxf file from librecad. E.g. see this file
http://netcup.bokomoko.de/~rd/Obergeschoss.dxf
I would like to print the part with the layout (floor plan) on the left, not the profiles on the right.
Any hint is welcome.
Many thanks
Rainer
Re: Printing Issue
Go to 'edit - current drawing preferences - paper' and set a paper size first. In 1:50 it won't fit on A4 or A3. Be sure your printer is set to the same size. Then go to print preview. You will see the paper sheet in white under the drawing. Set the printing scale desired. If it doesn't fit on the largest available papersize you can set a smaller scale like 1:100. You can shift the paper to the wanted position with the mouse. And print!
Re: Printing Issue
rdorsch
Thanks dellus, for your quick response, that works well.
Rainer
Rainer Dorsch
http://bokomoko.de/
