Printing drawing from LibreCad.
8 messages Options Options
Jim Thompson
I am unable to print a drawing from LibreCad.
The printer works fine on any other type of document that I have tried; just not with LibreCad dxf files.
Can someone advise please?
Re: Printing drawing from LibreCad.
Please try: File -> Export as PDF?
If successful, try to print the generated PDF.
If you are running Windows or OSX, there could be a packaging issue.
Jim Thompson
Thanks for the reply.
I am able to print .pdf files. I know that much already.
I am using Linux Mint 17 operating system. I only use Windows XP for a couple of programs that Linux does not support.
can you provide more details?
step by step with what happens after "File -> Print"?
alt78
Hello all!
I have the same problem - can't print or export my drawings. Ubuntu 14.04, LibreCAD 2.0.8.
file/export/export as image/png makes a zero-lengths file.
file/print/pdf (CUPS) makes pdf with one line. it seems as drawing very zoomed.
now I use print-screen.
what should I do to export/print normally?
First, have a look at "File / Print Preview", and adjust scaling, center, etc.
Second, try File  / Export Export as PDF, if you still have problem with File/Print.
If you still have issues there, please upload a test case dxf.
We would like to know how the printing part works, before releasing 2.0.9
alt78 wrote
Hello all!
alt78
dxli, thanks. After setup with PrintPreview all works with pdf. :) It works fine with CUPS, and with "Print to file (PDF)".
Now I can add pdf to my LaTeX documents.
But "export as image" still not works, generates a zero-lengths file. I want a png with 300dpi resolution.
With respect, Alexander.
In earlier experiments I have found out with resulting pixel size over about 10000x10000 or 12000x8000 you get those 0-byte files. So try a lower resolution or smaller "paper size". Or transform the pdf to pixels in an external program.
regards dellus
