Printing to PDF via command line
13 messages Options
mandeep7
Can I use LibreCAD to print my DXF file to PDF using command line?
I am using Linux and here are some details:
<q>
Version: master
SCM Revision: 2.0.8
Compiler: GNU GCC 5.3.0
Qt Version: 5.5.1
</q>
It may be some command like:
librecad demo.dxf --print demo.pdf
If it's not possible in LibreCAD, then can you suggest me something else?
Mandeep Singh
Re: Printing to PDF via command line
There's a feature request of command line converter:
LibreCAD --convert foo.dxf foo.pdf
LibreCAD --convert foo.dxf foo.svg
LibreCAD --convert foo.dwg foo.dxf
it might worth to implement them. Would you like to help?
Another idea, implement a plugin. Need to read about LibreCAD plugin interface first.
<q>
Version: master
SCM Revision: 2.0.8
Qt Version: 5.5.1
</q>
rolgiati
On Fri, 18 Dec 2015 12:28:53 -0700 (MST)
There are plenty online dxf 2 pdf wepages...
Cheers,
Ron.
                     Always remember that you are unique.
                           Just like everyone else.
mandeep7
On Sat, Dec 19, 2015 at 12:58 AM, dxli [via LibreCAD]
Yes. How can I get started with that?
Can you point me to the relevant resources?
Mandeep Singh
http://mandeep7.wordpress.com
https://github.com/mandeeps708
“To err is human, but to really foul up everything, you need root password.”
Mandeep Singh
Have a look at the class qc_applicationwindow, and slot slot functions for file open, file saving, and exporting.
May create a new slot to do the conversion and be called using cli parameters
Mandeep Singh
mandeep7
On Sat, Dec 19, 2015 at 3:13 AM, dxli [via LibreCAD]
> parameters
I gave Kabeja a try.
Can't we use it in LibreCAD as an extension?
It's Apache licensed.
http://kabeja.sourceforge.net/
https://github.com/fuzziness/kabeja
Mandeep Singh
Mandeep Singh
Can you extend a C++ / Qt program with a Java library?
It seems nasty; and I think it would be overkill since we can already create PDF files.
To be clear: are you talking about the OS command line or the command line inside of LibreCAD?
Look at QC_ApplicationWindow::slotFilePrint
It could use some cleanup, and could be split into more than one function.
Also look at handleArgs in main.cpp
mandeep7
On Sun, Dec 20, 2015 at 2:08 AM, ravas [via LibreCAD]
> PDF files.
> inside of LibreCAD?
OS command line.
Sorry, I've not undergone LC code as of now. As LibreCAD prints to PDF
from GUI. I just want to do it from Command line.
Thank you.
Mandeep Singh
Mandeep Singh
mandeep7
> interface first.
Hi there!
Is the project list for GSoC 2016 updated?
Can we consider this as a standalone project to be in GSoC?
Mandeep Singh
Mandeep Singh
I feel this can be a good warm-up project, but doesn't seem to fit the length of gsoc.
In addition, can we add basic piping to LibreCAD:
librecad <<EOF
line 0,0 10,10
circle 5,5 5
papersize letters
export output.svg
export output.pdf
EOF
Here we can have flexibility of what commands to support, to get a good project.
What do you think?
<quote author="mandeep7">
> interface first.
Hi there!
Mandeep Singh
In reply to this post by mandeep7
As rolgiati pointed out, there are a lot of free tools already available to batch convert dxf to pdf.
Let's avoid reinventing another wheel.
A GSoC project would preferably add something that is frequently requested:
- scripting
- properties dockwidget
- grouping of layers
- show the entities in each layer (tree view)
We aren't lacking in feature requests.
https://sourceforge.net/p/librecad/feature-requests/?source=navbar
https://github.com/LibreCAD/LibreCAD/labels/request
hsrai
In reply to this post by rolgiati
On Sat, Dec 19, 2015 at 1:27 AM, rolgiati [via LibreCAD]
>> > else?
I could not find any which is FOSS.
If I am missing any, please point out.
H.S.Rai
H.S.Rai
