Problem scaling an image
Blain Albin
Trying to scale an image that I imported.  I'm using the Modify -> Scale command.
The image I've imported is a jpg sized about 3882 x 632 and is 72dpi
I will start the command, select the image, set reference point.
The Scale Options dialog comes up.
I choose Delete Original.
Set scale to 0.5.
Choose Isotropic scaling
Use current attributes is unchecked
Use current layer is unchecked.
When I click Ok my image disappears.  It's like it deletes the original then doesn't redraw the new image.
It works fine if I use it on a normal line object like a square.
Can anyone duplicate this?
Using v2.1.3
Windows 10
Thanks
Re: Problem scaling an image
Yes, I can reproduce this. Funny thing is, I have never realized this before, although I have been playing around with that feature a lot. If you do 'autozoom' the image is back. Perhaps I always did this automatically. It does not react to other zooming or 'redraw', however.
Blain Albin
Thanks for the reply dellus.  And thanks for the work around.  At least I can actually get the intended results.  I was stuck before.
Thanks again.
peentoon
Indeed, same problem here, and workaround does the job but it's quite annoying.
Do you know if there's any plan to fix this?
Is fixed in 2.2.0rc.
