Problems about constraints, and dimensions
ddddd
Do librecad have 'constraints' functions?
I want to draw a line that one end point coincides with a circle, while another side keeps in same position.
I remember librecad had both constraints and dimensions functions in the old version.
something like I can set the constraints of lines by clicking them while pressing the control buttom, or after seting the dimensions of lines, I can click the label to change the length of the line or the distance between this line and other line.
I haven't use this application for many years, this app changes a lot.
your answers are appriciated
Re: Problems about constraints, and dimensions
'I remember librecad had both constraints and dimensions functions in the old version.'
Are you  sure you are talking about LibreCAD? I have never read about constraints with LibreCAD. There is Tools - Modify - Properties where you can edit some values, depending on the kind of entity, but probably not to the extent you expect.
You can stretch the endpoint of a line to a different position by clicking on the line, thus highlighting it, grab it at one of the small square handles and pull it elsewhere. If you want to put it on a circle, have 'Snap on Entity' activated.
Alternatively you can use Tools - Modify - Stretch.
Fredxx
Hello!
I am sure i have also managed to use this function previously.
However i dont know if contstraints is the correct term.
That when i move a line, the other follows, keeping the snap-location.
