Hello, - Using LibreCAD master with Qt Creator, I noticed that there is 2 "Run configuration" in "Projects"->"Run Settings"->"Run configuration:" These "Run configuration" are: src ttf2lff - I think that "ttf2lff" has nothing to do here, and must be removed. - For an unknown reason, the "ttf2lff" "Run configuration is frequently selected, and this prevent LibreCAD to be run from Qt Creator. - Any comment on that? Claude |
The ttf2lff is an utility for convert ttf to lff fonts, and is only build in linux because it require freetype.
About "Run configuration:" issue: the ttf2lff.pro is not included in subdir target for windows, but for some reason is parsed and added in QtCreator ignoring the "not win32" condition. I have done some testing (removing librecad.pro.user): - I added "ttf2lff" before "src" -> ttf2lff is selected - I added "ttf2lff" after "src" -> ttf2lff is selected -I removed CONFIG += ordered and made the two previous test -> ttf2lff is selected -I I have set all the content of ttf2lff.pro in "not win32" condition -> ttf2lff is selected & fail to build -I made other test I do not remember -> ttf2lff is selected My conclusion: In qtcreator if the target is subdir all pro files are parsed then sorted alphabetically and set in "Run configuration:" the last (in alphabetical order) project file with target=app. My sulution (really a hack): I renamed (and push) "ttf2lff" dir & pro file as "attf2lff" and as default "src" configuration is selected. Cheers, Rallaz |
On 15/12/2011 13:13, Rallaz [via LibreCAD] wrote: > > The ttf2lff is an utility for convert ttf to lff fonts, and is only > build in linux because it require freetype. > Thank you for the information. > > About "Run configuration:" issue: > > the ttf2lff.pro is not included in subdir target for windows, but for > some reason is parsed and added in QtCreator ignoring the "not win32" > condition. > > I have done some testing (removing librecad.pro.user): > - I added "ttf2lff" before "src" -> ttf2lff is selected > - I added "ttf2lff" after "src" -> ttf2lff is selected > -I removed CONFIG += ordered and made the two previous test -> ttf2lff > is selected > -I I have set all the content of ttf2lff.pro in "not win32" condition -> > ttf2lff is selected & fail to build > -I made other test I do not remember -> ttf2lff is selected > > My conclusion: > In qtcreator if the target is subdir all pro files are parsed then > sorted alphabetically and set in "Run configuration:" the last (in > alphabetical order) project file with target=app. > > My sulution (really a hack): > I renamed (and push) "ttf2lff" dir & pro file as "attf2lff" and as > default "src" configuration is selected. > - Humm... Really interesting. - I think this is the kind of situation that explain why so much people do prefer manage projects manually. Managing project through an IDE can really be a nightmare in some situation. - Will take a look, if it is possible to built LibreCAD from Cygwin command line... Regards, Claude |
- Replying to myself... > > - Will take a look, if it is possible to built LibreCAD from > Cygwin command line... > - I forgot I already tried to built LibreCAD on Cygwin, and this was not possible because "qmake" is not present on Cygwin. Claude |
> > My sulution (really a hack): > I renamed (and push) "ttf2lff" dir & pro file as "attf2lff" and > as default "src" configuration is selected. > - I just downloaded LibreCAD master from GIT, and your hack does not work for me on a Windows 7 Professional 64-bit computer. "ttf2lff" remain the default run configuration :-( Claude |
2011/12/16 ClaudeQC [via LibreCAD] <[hidden email]>:
> > - I just downloaded LibreCAD master from GIT, and your hack does not > work for me on a Windows 7 Professional 64-bit computer. > "ttf2lff" remain the default run configuration :-( > > Claude > First delete "librecad.pro.user" then open qtcreator, this file is created by qtcreator each time you open "librecad.pro". Cygwin is a bad idea because QT for windows is build with MinGW and, I seem, the ABI is not compatible. For command line build in windows you can use: with cmd.exe: write a batch file like: SET PATH=%PATH%;C:\Qt\Desktop\Qt\4.7.4\mingw\bin;C:\Qt\mingw\bin cmd.exe with MSYS bash: Install msys from nimgw.org modify the configuration to add in the path the location of qmake.exe. In bot cases is bad to add the qmake dir-path in system var "PATH" to avoid cygwin collision. Rallaz |
