Quote are not displayed above the line
follaiv@alice.it
I change PC and I download again librecad. When I upload an old drawing I noticed that the quote are not shown and instead of the number there is a square box.
I try to do a simple circle and I quoted the diameter and instead of the number it appear the square box.
Is there some bug problem or there is some setting to do.
How Can I solve this problem. You can write me in Italian if possible
Re: Quote are not displayed above the line
perepujal
Probably you have "Draft mode" activated?
Draft mode helps with BIG drawings to speed up rendering.
If your drawing renders quickly without Draft Mode activated then there is no need to activate it.
https://forum.librecad.org/text-not-showing-td5717293.html
In reply to this post by follaiv@alice.it
Switch off Draft mode.
I remember we discussed before, but forgot about the details.
Should we write the text "draft" to the window corner, if rendered in draft?
It's a display thing, probably won't be printed out.
