Re: *** GMX Spamverdacht *** Embroidery Application
RoboMod
Can You give us an url or example?
I have been developing an embroidery application handling many formats, I am planning on adding CAD functionality. What are the guidelines for using code from LibreCAD? The applications are actually very similar and was wondering if LibreCAD would want to add embroidery capabilities as some sort of plug-in (running the UI in a simplified/ stripped down mode).
http://forum.librecad.org/Embroidery-Application-tp5706672.html
JV
JV
embroidermodder.sourceforge.net/ is the URL. In the source code you can find a subdirectory where we migrated to use qt for the ui allowing it to run cross platform and also added many new formats.
