Lisando,
thanks for taking care of this. Due to how LIbreCAD internally searches for files, teh documentation has to be put into this directory: /usr/share/doc/librecad/doc (note the extra doc) Will that work for you? Remember, only the two mentioned files are needed. Ries On Jun 19, 2011, at 10:31 AM, Lisandro Damián Nicanor Pérez Meyer wrote: > On Sun 19 Jun 2011 12:25:08 Lisandro Damián Nicanor Pérez Meyer escribió: > [snip] >>> /usr/share/librecad/doc >>> /usr/share/doc/librecad/doc >>> >>> I did notice that on ubuntu the directory is /usr/share/doc/librecad-doc >>> this looks a bit odd to me because no other package I currently have >>> installed does it like that (adding -doc to the package name). > > Forget what I said, it should be /usr/share/doc/librecad/. > > I'll fix it asap. > > Thanks for the bug report!! > > -- > "With great power comes great responsibility." > Peter Parker's uncle. > > Lisandro Damián Nicanor Pérez Meyer > http://perezmeyer.com.ar/ > http://perezmeyer.blogspot.com/ |
On Sun, Jun 19, 2011 at 11:43 AM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote: > Lisando, > > thanks for taking care of this. > > Due to how LIbreCAD internally searches for files, > teh documentation has to be put into this directory: > > /usr/share/doc/librecad/doc (note the extra doc) yes that works /usr/share/doc/librecad/doc |
Ries,
There is going to be a delay in uploading, one of the libraries is currently being rebuilt: https://buildd.debian.org/status/package.php?p=dxflib Once it's done and published Lisandro will be able to upload the helpfiles fix (installing them in /usr/share/doc/librecad/doc,) which I will then manually push to the Ubuntu PPA. ~Scott |
Scott,
can I just test this by running apt-get update apt-get upgrade ? Ries
On Jun 19, 2011, at 12:48 PM, showard314 [via LibreCAD] wrote: Ries, |
On Sun, Jun 19, 2011 at 7:32 PM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote: > Scott, > can I just test this by running > apt-get update > apt-get upgrade > ? > Ries Once it is set up it will work. It's a little more complicated because the packages usually have to trickle down from debian -> ubuntu -> ubuntu PPA I've decided that its inefficient this way, so I just removed the ubuntu PPA from that chain. I'll be setting it up so that those builds will be independent of the official builds so that it can get to users faster. Tonight I have some time I'll be able to mess with it a bit to get it working so we have total control over it instead of relying on the other build machines. ~Scott |
Ok, it's up
On Sun, Jun 19, 2011 at 10:25 PM, Scott Howard <[hidden email]> wrote: > On Sun, Jun 19, 2011 at 7:32 PM, R. van Twisk [via LibreCAD] > <[hidden email]> wrote: >> Scott, >> can I just test this by running >> apt-get update >> apt-get upgrade >> ? >> Ries Ok, it's up and running now. Every day it will download the github master branch and build a package automatically if there were any new commits. Doing an apt-get update apt-get upgrade will keep your installation up to date. You can see the status of builds here: https://code.launchpad.net/~librecad-dev/+recipe/librecad-dev-daily It will work for Maverick (10.10) and higher versions of Ubuntu. This was a little more difficult that normal since Lisandro was doing most of the work and I am away from development machines to test things. He did a great job putting the package together even though he was unfamiliar with some of the changes (e.g. this release added help files, logos.) While the helpfile bug should be fixed in the PPA, we are still working on uploading the fixes to the official Ubuntu and Debian archives (there is a delay because of the library I pointed out earlier that is preventing the new package from being uploaded) |
Scott, Lisandro,
I have updated ubuntu and indeed now a directory /usr/share/librecad/doc is created, but it still contains the wrong set of documentation. Now, it could be that I mis-understand the purpose of that directory, may be Ubuntu requires pure HTML documentation? but the things is that LibreCAD cannot read the pure HTML version to show in the inline help system. LibreCAD really need the two files for the help system to function. - LibreCADdoc.qch - LibreCADdoc.qhc Remember, they are generated files! I hope that makes sense. Ries |
On Tue 21 Jun 2011 10:26:07 R. van Twisk [via LibreCAD] escribió:
> Scott, Lisandro, > > I have updated ubuntu and indeed now a directory /usr/share/librecad/doc is > created, > but it still contains the wrong set of documentation. > > Now, it could be that I mis-understand the purpose of that directory, may > be Ubuntu requires pure HTML documentation? but the things is that > LibreCAD cannot read the pure HTML version to show in the inline help > system. > > LibreCAD really need the two files for the help system to function. > > - LibreCADdoc.qch > - LibreCADdoc.qhc still have some packaging issues due to the dxflib change. The program needs the qhc and qch files, so it should have it, don't worry about that, just give us some time :-) (this weekend I have been working from my laptop out of home, so neither Scott nor I had much time to properly review this). Let me ask you a question: are the HTML up to date so as to add them to the packaging as another form of documentation (not online doc)? On another issue, I had subscribed to the list, but I never got a confirmation mail (maybe nabble doesn't send them?) Kinds regards, Lisandro. -- "I'm your worst nightmare". Eric S. Raymond to Craig Mundie Lisandro Damián Nicanor Pérez Meyer http://perezmeyer.com.ar/ http://perezmeyer.blogspot.com/ |
On Tue 21 Jun 2011 11:18:38 Lisandro Damián Nicanor Pérez Meyer escribió:
[snip] > Let me ask you a question: are the HTML up to date so as to add them to the > packaging as another form of documentation (not online doc)? Scott already answered me this :-) Kinds regards, Lisandro. -- If little green men land in your back yard, hide any little green women you've got in the house. Mike Harding, "The Armchair Anarchist's Almanac" Lisandro Damián Nicanor Pérez Meyer http://perezmeyer.com.ar/ http://perezmeyer.blogspot.com/ |
On Tue, Jun 21, 2011 at 9:26 AM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote: > Scott, Lisandro, > > I have updated ubuntu and indeed now a directory /usr/share/librecad/doc is > created, > but it still contains the wrong set of documentation. > > Now, it could be that I mis-understand the purpose of that directory, may be > Ubuntu requires pure HTML documentation? but the things is that LibreCAD > cannot read the pure HTML version to show in the inline help system. > > LibreCAD really need the two files for the help system to function. > > - LibreCADdoc.qch > - LibreCADdoc.qhc > > Remember, they are generated files! I hope that makes sense. We're aware of it - for some reason Ubuntu and Debian's installation scripts are not listening to our installation instructions. Everything is unix/resources/doc is supposed to end up in /usr/share/doc/librecad/doc - but it's still empty. So then we tried installing everything from support/doc as well (since the files are generated in that folder), but it still didn't copy over the qhc and qch files but did copy over all the html files that you see. We worked on it a bit this weekend and haven't found out why it's happening. Lisandro is currently working on it. ~Scott |
Scott, Lisandro,
since I did see the update I was thinking it was all in place and corrected. No rush... Ries On Jun 21, 2011, at 9:25 AM, showard314 [via LibreCAD] wrote: On Tue, Jun 21, 2011 at 9:26 AM, R. van Twisk [via LibreCAD] |
On Tue, Jun 21, 2011 at 10:38 AM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote: > Scott, Lisandro, > since I did see the update I was thinking it was all in place and corrected. > No rush... > Ries Lisandro just found that the files are not being generated at all, for some reason. Hopefully this is a clue to get this fixed... Also, every night there will be an update for whatever you put into github. It's automagic now, the PPA has become alive! ~Scott |
On Mar 21 Jun 2011 11:55:05 showard314 [via LibreCAD] escribió:
> On Tue, Jun 21, 2011 at 10:38 AM, R. van Twisk [via LibreCAD] > > <[hidden email]> wrote: > > Scott, Lisandro, > > since I did see the update I was thinking it was all in place and > > corrected. No rush... > > Ries > > Lisandro just found that the files are not being generated at all, for > some reason. Hopefully this is a clue to get this fixed... Scott: somehow the orig.tar.gz that g-bp generates it's not the same as the one I originally uploaded, so expect rejects if you use that tar.gz. Kinds regards, Lisandro. -- Moore's Law: The speed of processors will double every 18 months. Gate's Law: The speed of software will halve every 18 months. Mysticalfruit en Slashdot Lisandro Damián Nicanor Pérez Meyer http://perezmeyer.com.ar/ http://perezmeyer.blogspot.com/ |
