		A little late to the party.  As a Civil Engineer, I am used to scaling up/down as elements outside of the building envelope may require.  I measure an element in the drawing (say - a line, maybe a property line - or the width of a desk or interior wall if inside the building envelope), one that is long, and one that has a known dimension.  If the element measured is too long (say), I divide the smaller known dimension by the larger measured dimension to establish the percentage of scale reduction required.  Then I command:
  SCALE==>(Select to scale)
 SELECT ALL [button]==>
 right click again in the drawing==>
 SCALE==>(Select reference point)
 0,0 [or other appropriate reference point]==>
 [load the calculated percentage into the ISOTROPIC SCALE menu]==>
 <ENTER>
  Save Early - Save Often, in particular immediately prior to SCALE.
  Warning:  Some blocks do not react well to scaling; dimension arrowhead blocks from AutoCAD in particular.
  UNDO (after SCALE) doesn't get it done for me.  Is there a presetting for the amount of allowable buffer?
  When a commands "blow up" unexpectedly (I am new to LibreCAD), I close and reload the drawing, then try something else.
