Referencing Image from a PlugIn
5 messages Options Options
CLamb
I would like to develop a plugin to fit a line to a set of points in a bitmap image. LibreCAD doesn't seem to allow selection of part of a bitmap so I would have the user draw a polygon enclosing the points to be used. I don't see any easy way to retrieve an image though. The only way I see is to use getAllEntities and then search it for the only Image entity. This seems cumbersome. Is there a better way of doing this?
Re: Referencing Image from a PlugIn
Other plugins use
doc->getSelect()
which returns a list of selected objects.
When the polygon is created as polyline, then selected with image, you should get 2 objects.
One is the polyline, the other the image.
I don't know what getEnt() and getData() will return for polyline and image, but I assume that it should be possible to extract the vertices from these data and also the image path and location.
But I never used image or polyline in plugins, so it's also possible, that the interface lacks functionality here.
perepujal
In reply to this post by CLamb
Just an snippet from an old, unfinished and abandoned plugin I started long time ago.
HTH
void LC_ImageVec::execComm(Document_Interface *doc,
                             QWidget *parent, QString cmd)
    Q_UNUSED(cmd);
    Q_UNUSED(parent);
    QPointF base1;
    Plug_Entity *img = doc->getEnt("Select an image");
    if (img == NULL) return;
    QHash<int, QVariant> imgData;
    img->getData(&imgData);
    if (imgData.value(DPI::ETYPE) != DPI::IMAGE) return;
    QPointF bottomLeft, dir;
    bottomLeft.setX(imgData.value(DPI::STARTX).toDouble());
    bottomLeft.setY(imgData.value(DPI::STARTY).toDouble());
    pixelSize.setX(imgData.value(DPI::SIZEU).toDouble());
    pixelSize.setY(imgData.value(DPI::SIZEV).toDouble());
    dir.setX(imgData.value(DPI::ENDX).toDouble());
    dir.setY(imgData.value(DPI::ENDY).toDouble());
    QString name = imgData.value(DPI::BLKNAME).toString();
    QImage image;
    if ( !image.load (name) ) return;
CLamb
But how does one select an image?
perepujal
File Import Insert Image to put it in the drawing,
then click it to select, alternative you could drag a rectangle enclosing it
or crossing it, depending on the direction of the drag.
Once it is selected, your code could use doc->getSelect() as LordOfBikes says.
The snippet I posted uses doc->getEnt("Select an image") which not cares
about what it is selected and prompts you to click an image.
