Reporting minor bugs
Scribbler
Since yesterday I am using, what I thought was LC 2.0.0.beta2 under Debian 7.0  (though when I look in Help|About it says:
SCM Revision 2.0.0beta1 Compiled on: Feb 25 2013.
But whatever version it is exactly, I've already spotted a couple of small inconsistencies and was wondering where I can best report these (or check whether they've been reported already).
For instance: the text of the new addition to the status bar "Total Length" is not affected by the Fontsize Statusbar: parameter in Edit|Application Preferences|Appearance.
It's just a minor bug as is the other I've found but I would like to know exactly where to check and possible report such things.
TIA
Re: Reporting minor bugs
Scribbler
OK. Replying to myself here, having done a bit more research!
So I've joined SourceForge, subscribed to LibreCAD and found:
https://sourceforge.net/p/librecad/bugs/new/.
I'm not sure exactly where to report the bug (aka Create the Ticket) though?
Do the "Groups"  1.0 and 2.0 correspond to releases 1.0.0 and 2.0.0 (beta) of LibreCAD - or am I right off track?
A little more information on filing a bug would be appreciated...
cantcode
hi,
here are some hints:
http://librecad.org/cms/home/get-help.html
Just (on Sourceforge) go to Tickets->Bugs and then "Create Ticket".
If you press "Create Ticket" you can select the "Milestone" 1.0, 2.0, ... .
So I guess 1.0 is for 1.0.X.X.X and 2.0 is for the 2.0.X.X.X release.
Scribbler
Thanks cantcode.
At the moment I'm figuring out how to search through tickets.
When I'm a bit happier with that I'll give your suggestion a try.
I'm using LC 2.0.0-beta2 so I'll go for posting under Milestone 2.
I assume someone will yell if I'm not doing it right..
Scribbler.
cantcode
"I assume someone will yell if I'm not doing it right."
A bug report with a wrong milestone is better than no bug report at all ;)
