Actually, the workflow is tricky for new users. It's mostly the same for many methods like rotate, scale:
If you have selected something to rotate before start "rotate",
1, following the mouse icon in the status bar;
2, select rotation center, reference, target;
3, the dialog showing up next would allow more options.
If "rotate" is started without selection, entities need to be selected, and "enter" should be pressed after selection to start rotation center selection.
myCAD wrote
Dear Forum,
when I use the "Rotate" tool, how can I do to rotate an object 90 degree? What should I write on Command Line? I tried "90", "@90", but no success.
Thank you.
