Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hello...
I have trouble rounding arc with line. In attached image 1 is shape without rounding. in image 2 the right corner is rounded as I want in image 3 I try to do same as in image 2 but got wrong result every time. ![]() ![]() ![]() test.dxf |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I have no trouble on rounding: Version: master SCM Revision: 2.0.4 Compiler: GNU GCC 4.8.2 Qt Version: 4.8.6 Compiled on: Jun 24 2014 Runing on Ubuntu 14.04 It works corectly on one side of arc but not on other. Slavko. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On 05. 11. 2014 18:55, dxli [via
LibreCAD] wrote:
I have no trouble on rounding: Actualy rounding works but trimming not. If I uncheck Trim (checkbox near Radius entry) then I got added radius and existing lines untact. But If I check Trim then lines are trimmed in wrong side. I just check if I apply radius (without trim) and then trim manualy. And manual trim doesn't work either. (it cut wrong side). So problem is not in "Roun" but in "Trim". Slavko. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Please test behavior in 2.0.6, or even better, in latest git HEAD.
We fixed some trimming behavior after 2.0.4
... [show rest of quote]
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
After enabling
ppa:librecad-dev/librecad-daily and updating to 2.0.7 trimming/rounding works as is expected. Just hope that this version is not to "unstable". Slavko. On 06. 11. 2014 16:06, dxli [via LibreCAD] wrote: Please test behavior in 2.0.6, or even better, in latest git HEAD. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
we fixed some crashing bugs since 2.0.6, so, the current git HEAD should be more stable than 2.0.6.
Up to now, the git HEAD has some features working better than 2.0.6 as well. I am going to push large patch later. While I will try to be careful, more testing/QA is welcome.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
For now I will try to stay on
daily-ppa. I don't like to compile from source if not absolutely
necessary.
Thanks for solving trouble. Slavko. On 06. 11. 2014 17:42, dxli [via LibreCAD] wrote: we fixed some crashing bugs since 2.0.6, so, the current git HEAD should be more stable than 2.0.6. ... [show rest of quote]
