Run time error
10 messages Options
Run time error
yadvir kaur
While running a LibreCAD program in Qt Creator, Terminal either displays a
blank window instead of a command prompt or it displays:
Cannot connect creator comm socket /tmp/qt_temp.Zz3650/stub-socket: No
such file or directory
Press <RETURN> to close this window...
but the same modified program is displaying correct resuls while using
text editor by giving commands in terminal.
 Please tell me what is the problem??
Re: Run time error
yadvir kaur
 terminal opens  up itself when I press the run button of Qt creator with that error message as shown
Re: Run time error
hsrai
In reply to this post by yadvir kaur
On Mon, Jun 17, 2013 at 12:49 AM, yadvir kaur [via LibreCAD]
Read:
http://stackoverflow.com/questions/14010521/cannot-connect-creator-comm-socket-tmp-stub-socket-no-such-file-or-directo
HTH
H.S.Rai
H.S.Rai
Re: Run time error
Yadvir Kaur
In Qt Creator
Menu | Tools | Options | Environment | General | System | Terminal
I changed "x-terminal-emulator -e"  to " /usr/bin/xterm -e"
Still it is not giving the result. Qt is giving output :
Starting /home/abc/LibreCAD/unix/ttf2lff...
/home/abc/LibreCAD/unix/ttf2lff exited with code 0
Terminal is opening up by itself.
Re: Run time error
In "build & run kit selector..." change "ttf2lff" to "src"
Re: Run time error
Yadvir Kaur
There is no such path as
/home/abc/LibreCAD/unix/src
And should I change "x-terminal-emulator -e"  to " /usr/bin/xterm -e"
Re: Run time error
you do not have to change any path
In Qt Creator select src (src.pro) instead of ttf2lff (ttf2lff.pro)
In bottom-left, computer icon just above run icon
Re: Run time error
cantcode
In reply to this post by Yadvir Kaur
as Rallaz already told, try to change the run option
Image and video hosting by TinyPic
Re: Run time error
Yadvir Kaur
Thanks for the solution, problem is solved :)
Re: Run time error
Yadvir Kaur
Thanks for the solution :) it was irritating me from a couple of days. Finally solved.!
