There is no way to fit it automatically into a certain size. The scaling factor has to be calculated.
Select your entities, then go to Tools - Modify - Scale. Select a reference point, then the scaling options box will appear. The scaling factor in your case will be 12/14.6, you can write it this way into the input field. Ok, and done.
