You can draw on top of the image. At least you should be able to do so. But the problem is if you try to select any entity within the image area, always the image gets selected instead. And if you lock the layer with the image, nothing can get selected. This is a bug. From earlier discussions it seems this cannot be easily fixed.
A workaround suitable for some operations is selection by pulling up a window around the desired entities. This works, but is of no use for many tools.
So you can draw, create entities, but can (almost) not edit them.
