Select Window snap use - locked up drawing
Land Owner
I switched from Select Entity to Select Window and back a couple of times.  Now, the drawing is locked in Select Window.  I cannot switch back to Select Entity.  What am I doing wrong?
Ordinarily, LibreCAD drawings defaults to Entity Select.  Currently, the drawing I am in, the default has become Windows Select, as if there is a command awaiting execution.  I have looked far and wide and find no such command.  I am stymied...
I can put in individual lines, circles, and a series of polylines, but I cannot select any specific entity after these are put into the drawing.
It is one drawing, which I could restart from a backup, but had hoped to find the solution in case this happens again.  Other drawings when opened, operate in the manner expected of LibreCAD.
Re: Select Window snap use - locked up drawing
chrissielips
Did you figure out this issue?  I am currently encountering the same problem.  My drawing seems to have got into a select window mode that I don't know how I got into and I can't get out of.
What's your version of librecad?
Could you provide a procedure to  reproduce
