Hi, I am using LibreCAD SCM Revision 2.0.9 and I have been unsuccessful at setting the scale for a drawing. I imported a .png image of a PDF scale drawing with a paper scale of 1 inch = 50 feet with a paper size of 34 inch width by 22 inch height. I see the useful reference for Common Drawing Scales at https://librecad.readthedocs.io/en/latest/appx/scales.html, but I don't see an option to set any of those scales in the LibreCAD version that I am currently using.
How can I set the scale of 1 inch = 50 feet? I have the units set as inch for both the Application and for the current drawing. Thank you. Irucka |
You have to get the scale to number. As i*m born and raised in a country with uses only metric system, can't calculate it for you, but I guess you could find online calculator inches to feet from the net.
In reply to this post by Irucka
1 inch = 50 feet makes 1:600. Just type this into the scale box in Print Preview and confirm with Enter.
Or is your question how to properly import a .png image from a pdf or a scan of a real paper plan? |
In reply to this post by aman
Hi, thank you for your suggestion.
________________________________________ From: aman [via LibreCAD] [[hidden email]] Sent: Tuesday, May 12, 2020 11:03 AM To: Embry, Irucka Subject: Re: Set Engineering Scale of 1 inch = 50 feet Caution! This E-mail originated from outside the university. Please use caution when opening attachments, clicking links, or responding to requests. You have to get the scale to number. As i*m born and raised in a country with uses only metric system, can't calculate it for you, but I guess you could find online calculator inches to feet from the net. ________________________________ If you reply to this email, your message will be added to the discussion below: https://forum.librecad.org/Set-Engineering-Scale-of-1-inch-50-feet-tp5718851p5718852.html To unsubscribe from Set Engineering Scale of 1 inch = 50 feet, click here<https://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5718851&code=aWVtYnJ5QG15LnRuc3RhdGUuZWR1fDU3MTg4NTF8LTE4NDUwMDAzMjk=>. NAML<https://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> |
I have a PDF of a scale drawing (at 1 inch = 50 feet) that I exported as a PNG using The GIMP. I imported the PNG image into LibreCAD so that I could create a 10 foot buffer around some objects on the scale drawing. I then wanted to calculate the buffer area.
Thus, I was trying to set the engineering scale at 1 inch = 50 feet & also set the dimensions of the page in LibreCAD. Thank you. ________________________________________ From: dellus [via LibreCAD] [[hidden email]] Sent: Tuesday, May 12, 2020 5:05 PM To: Embry, Irucka Subject: Re: Set Engineering Scale of 1 inch = 50 feet Caution! This E-mail originated from outside the university. Please use caution when opening attachments, clicking links, or responding to requests. 1 inch = 50 feet makes 1:600. Just type this into the scale box in Print Preview and confirm with Enter. Or is your question how to properly import a .png image from a pdf or a scan of a real paper plan? ________________________________ If you reply to this email, your message will be added to the discussion below: https://forum.librecad.org/Set-Engineering-Scale-of-1-inch-50-feet-tp5718851p5718855.html To unsubscribe from Set Engineering Scale of 1 inch = 50 feet, click here<https://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5718851&code=aWVtYnJ5QG15LnRuc3RhdGUuZWR1fDU3MTg4NTF8LTE4NDUwMDAzMjk=>. NAML<https://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> |
Not quite clear if the problem is solved now. If not:
You have to know with what dpi value the png is exported from GIMP. 300 is a good choice. When then importing into LibreCAD set that at the Tool Options bar. ![]() Best insert it at the lower left corner of the frame. Then scale it up 600x (from your 1 inch = 50 feet) with Scale. Up to V 2.1.3 there is a bug that it will seem to be disappeared afterwards, AutoZoom brings it back. For further advice ask again if needed. |
