Split Line
Split Line
rdorsch
is it possible to split a line into n lines of equal length? I can scale and
copy, but is there something more elegant?
Thanks
Rainer
Rainer Dorsch
http://bokomoko.de/
Re: Split Line
LC V2.2.0 rc has the plugin "Divide". This does what you want.
In 2.1.3, well, more laborious. If for instance you want to split a line into 4 parts, use Modify - Divide, have Snap Middle activated and set Middle Points in the Tool Options bar to 3, select the line to be split and choose the first of the Middle Points as the cutting point. Then proceed the same way with the remaining line but reduce the Middle Points to 2 and so on.
Re: Split Line
rdorsch
Many thanks, it is always impressive how many "hidden features" LibreCAD has
Rainer
Am Sonntag, 30. August 2020, 20:34:06 CEST schrieben Sie:
> _______________________________________________
> If you reply to this email, your message will be added to the discussion
> below: https://forum.librecad.org/Split-Line-tp5719504p5719505.html
> To start a new topic under LibreCAD-user, email
> [hidden email] To unsubscribe from LibreCAD-user,
> visit
> https://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_co
> de&node=4499514&code=bWxAYm9rb21va28uZGV8NDQ5OTUxNHwyMzE1NTUxNzM=
Rainer Dorsch
http://bokomoko.de/
