Many thanks, it is always impressive how many "hidden features" LibreCAD has
Rainer
Am Sonntag, 30. August 2020, 20:34:06 CEST schrieben Sie:
> LC V2.2.0 rc has the plugin "Divide". This does what you want.
> In 2.1.3, well, more laborious. If for instance you want to split a line
> into 4 parts, use Modify - Divide, have Snap Middle activated and set Middle
> Points in the Tool Options bar to 3, select the line to be split and choose
> the first of the Middle Points as the cutting point. Then proceed the same
> way with the remaining line but reduce the Middle Points to 2 and so on.
> _______________________________________________
> If you reply to this email, your message will be added to the discussion
> below:
https://forum.librecad.org/Split-Line-tp5719504p5719505.html> To start a new topic under LibreCAD-user, email
[hidden email] To unsubscribe from LibreCAD-user,
> visit
https://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_co> de&node=4499514&code=bWxAYm9rb21va28uZGV8NDQ5OTUxNHwyMzE1NTUxNzM=
Rainer Dorsch
http://bokomoko.de/
