Three Questions about Dimensions
3 messages Options Options
Fran_iii
This post was updated on Aug 19, 2022; 5:56pm.
Setup:
- New Drawing: Letter size
- Drawing Prefernces - Units Tab
.. Main Drawing Unit = 1 inch
.. Format Decimal
- Drawing Preferences - Dimensions Tab ... shown below ...
- Draw a 100 x 100 Rectangle
.. Click Line > Rectangle
.. First Corner = 0,0
.. Second Corner = 100,100
- Draw the Horizontal & Vertical Dimensions as shown below ...
Question 1:
What do the the dimensions mean?
.. 100 inches by 100 inches or what?
Question 2:
How to get the dimensions to display in inches?
Question 3:
Under Drawing Preferences
What is X & Y Spacing?
When I change it I see no visible change on the drawing
Thanks for any help.
Re: Three Questions about Dimensions
Fran_iii
OK, I think I have this figured out... after some experimentation.
Options > Drawing Preference > Length Factor should be set to 1.
So if you paper is 8.5x11 inches...
And you draw a rectangle 8.5x11...
And you set Options > Drawing Preference > Length Factor = 1
And you draw a horizontal dimension along the top from the left corner to the right corner
The Dimension will read 8.5000 ... aka the width in inches
If you change the Options > Drawing Preference > Length Factor to be 2
The Dimension will read 17 ... 2 times 8.5
Wasn't obvious to me by inspection... until I experimented some with Dimension options.
I'm sure it is clear somewhere in the doc's but after an hour+ of reading & Googling I just decided to start experimenting over and over... and after awhile I got it.
Regarding... Question 3:
I still haven't had any luck finding out what that does... but I'll bang on it some more until I get or until some kind soul gives me a tip.
Land Owner
This post was updated on Aug 24, 2022; 3:16am.
In reply to this post by Fran_iii
X and Y Spacing are the "Grid marks" when you want them shown.  The larger the number, the fewer and further between Grid marks.
Say UNIT = INCH
At 10=X and 10=Y, grid marks will occur every 10" x 10" and the distance between each adjacent pair will be 10".
At 1=X, 10=Y there will be 1" x 10 marks in the X direction and 10" x 1 mark in the Y even though, zoomed out, there are lines of intersection only every 10".  Zoom in to see the smaller "X" marks.
A simple LINE from 0,0 to @10<45, then ALIGNED Dimension from ENDPOINTS makes the point clear in the 1=X and 10=Y.
