Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi all!
Is it possible to insert text with Ukrainian letters (different from Russian - there are only 4 of them)? Asking just because there is an option of Ukrainian GUI language... Thanks! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi drvlas,
looks like our Ukraine translation goes well with 88% translated. http://translate.librecad.org/pootle/uk/ As LibreCAD supports UTF8 encoding internally, it should support Ukrainian by defalt. dxli
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Well, maybe I'm doing smth wrong. Can you please tell me how to insert a text with such symbols: 0404 0407 0454 0457 0490 0491 (fromn Curillic Unicode table) How can I participate? |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by drvlas
As for Ukrainian symbols - it is a problem of used font (not implemented characters in used *.lff font), and not a bug of LibreCAD.
Please, tell font's maker to add this characters in default fonts redistributet with LibreCAD! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
OK, I've got you.
Thank you for an answer! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
The font maker are LibreCAD team
You have two options: 1) open a feature request in sourceforge.net indicating the font file (iso.lff p.e.) and the characters needed like 0490 2) create the characters yourself and send a patch to sourceforge indicating which are the new characters. To create new characters: File->open in filters select "lff font", the file are opened and each char are a block. create a new block called p.e. 0490 and draw the new char using arcs, lines or polylines then save it as "lff font" and the new char are ready to use. If you create the chars please send it as patch to include in newer version of LibreCAD license GPL2 or above are mandatory!!! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
The chars 0404, 0407, 0454, 0457, 0490 & 0491 are added in cyrillic_ii.lff
and commited in master branch, please check it. Missing links in previous post: feature requests http://sourceforge.net/tracker/?group_id=342582&atid=1433847 patches http://sourceforge.net/tracker/?group_id=342582&atid=1433846 |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I have not got you. What does it mean? What have I to check? And is it still a need in patshes? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I do not know the Ukrainian alphabet or the cirillic.
Attached in the second message are the file with the new chars. You would have to test whether the new characters are correct and your problem are solved. The feature request is not needed for this "problem" but if you find more missing characters then open a feature request. The patch link omly are needed if you are encouraged to collaborate. Remember that this project is done by volunteers and all collaboration are welcome |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Rallaz,
Please tell me how can I use the file. Collaboration: I think about the translating English terms to Ukrainian. Maybe I'd try to draw Ukrainian letters too, but only if somebody helps me with the start of the process. You see, I'm a dummy in software design. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I checked in my libraries, there's such file and its date: Last modified: 2011-09-29 So I have the latest vertion. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Apr 20, 2012; 6:01pm.
Not exactly! I copied the file you linked and saw: it is different from the one I've got with the LibreCAD earlier. So I put the new file in the library. And something happened! I can see some symbols. But not all. Let me show what is right and what is not: 0457 - OK 0407 - OK 0404 - OK 0454 - OK 0490 - OK 0491 - OK Symbols 0406 and 0456 are identical with English 'I' and 'i' - and they are being shown as blanks. Well, I can write them in English. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
The file linked are modified after read your post 0456 & 0406 are not mentioned in your previous post then only 0407, not bad :-D Of course!! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by feugeniy
Please note that the wqy-unicode.lff font file already contains the mentioned symbos. The wqy-unicode.lff was added for fully Chinese-Japanese-Korean font support as set by the 1.0.0 milestone.
