If you "edit the active block in a separate window", the changes are visible instantly in the main drawing also. Access that separate window via "Drawings". I had no problems doing any editing there.
But strange interactions depending on the layers conditions happen, which I do not understand myself. See also the recent postings from forum member electrosteam.
The idea of blocks is to keep your drawing file small and nimble, as the data of a blocks content is only written once in the file, even if it is inserted several times. With copy / paste the file gets bloated.
Sorry not to be able to help more.
