Warp Perspective
7 messages Options Options
Warp Perspective
Angelos58
Good morning everyone.
This is my first post.
Is there in LibreCad a warp perspective tool?
A workaround too.
Thank you
Angelo
Re: Warp Perspective
Currently, no.
Of course, if you want to construct perspective manually, we have enough line methods for that.
I think that's a very interesting method to add:
1, perspective of conic sections are conic sections, so we have enough geometry primitives for the method;
2, I have started to add a new skew method, and only the engine supprt is implemented so far;
3, we can add those two methods together completing our projection support: with skew for orthogonal.
A workaround too.
Thank you
Angelo
In reply to this post by Angelos58
What exactly do you want to use this for?
I want to support conic sections as well
flywire wrote
Angelos58
Thank you very much for link.
A lot of interesting issues.
Is there also tutorial for wrapping perspective a shape? For example a circle.
This post was updated on May 09, 2024; 3:09pm.
Not really a tutorial.
In LibreCAD, there's a drawing method to create an inscribed ellipse of a generic quadrilateral. The algorithm is based on:
A quadrilateral is a perspective of a square;
Finding the inscribed circle of a square is trivial;
The perspective of this circle gives the inscribed ellipse of the quadrilateral;
so the ellipse is found from the perspective of a circle.
My goal is to implement a way to allow specifying a perspective transform from GUI, and transform any selected entities (point, line, circle, ellipse, parabolas, splinepoints, cubic splines(need to verify the math)) to their perspective projection.
