Why save my files there?
2 messages Options Options
essex merv
Hi all, Being a new user to LC I've got lots of questions, but the most puzzling is this. I'm currently using Ver 2.1.3  & in Application Settings - Paths I've selected the default directories for saving my files, namely:
C:\Program Files (x86)\LibreCAD\resources\library , but  when I look in the Windows 10 file browser I find them in:  C:\Users\Mervyn\AppData\Local\VirtualStore\Program Files (x86)\LibreCAD\resources\library. Can anyone tell me please why LC decides to put my files where the Sun don't shine? PS. I'll shortly be loading Ver 2.2.0 rc3.
Keep safe
Merv Richmond
Re: Why save my files there?
It's Windows who relocate your files, not LibreCAD.
It is not recommend to store documents in Program Files folder.
I think UAC started with Windows Vista and since then access to Program Files and other system folders is read-only for regular users. You have to use administrator privileges to get write permission to these folders.
But it is not recommend to run LibreCAD with administrator privileges to bypass this behavior.
So what you have found is the shadow copy Windows creates for compatibility reasons.
When a program with regular user permissions writes to any file under Program Files, Windows creates a copy and save changes in the user folder.
This happens transparent, so the file open dialog should find the files when you navigate to Program Files folder. But inside Windows Explorer this mechanism is not active and you don't find the files where you expect them.
So best solution is to change the default folder to any location in your users document folder.
Same applies also to libraries, templates and folders you need write permission.
Concerning libraries, you can keep those installed with LibreCAD in Program Files folder, but add a path in Application Preferences in your user space for new or modified libraries. You should see folders from both locations in the library browser then.
