Wiki access
21 messages Options
12
Wiki access
Ferdi
I asked for write-access to the Librecad wiki two days ago. No reply yet. Should I wait longer or is there a different way to get access rights?
Re: Wiki access
Re: Wiki access
Ferdi
That was quick, thanks!
I worked a little bit on layout of http://wiki.librecad.org/index.php/LibreCAD_version_2,_users_Manual/Guide_-_by_Bob_Woltz
So far some diagrams are missing. I found the original (?) pdf-file. I'll check license. If OK I'll transfer the missing pictures soon. Should we improve/extend this manual or is it better to contribute to other wiki pages?
Re: Wiki access
Ferdi
Wiki-manual: is it possible to allow DXF file upload? If yes we could collect example DXF files there.
Re: Wiki access
You can upload a file and include file link in wiki pages.
"Upload a file" button can be found in the left panel under "Tools"
Re: Wiki access
Ferdi
But only graphic files, no files with "DXF" extension.
Re: Wiki access
Jim Winkler
The Terms of service link on http://wiki.librecad.org/index.php/Special:RequestAccount is red.
Re: Wiki access
RE: Wiki access
Jim Winkler
Hi Ries,
I don't seem to be able to access wiki.librecad.org. I did enter my email on the application as [hidden email]  I am logged in under the forum.
Am I missing something?
Thanks!
Jim
Date: Wed, 18 Mar 2015 11:16:18 -0700
To: [hidden email]
Subject: Re: Wiki access
Jim,
you have been enabled.
Ries
On Mar 18, 2015, at 7:13 PM, Jim Winkler [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/Wiki-access-tp5709959p5711221.html
To start a new topic under New user - Introduce yourself, email [hidden email]
http://forum.librecad.org/Wiki-access-tp5709959p5711222.html
To unsubscribe from Wiki access, click here.
Re: Wiki access
RE: Wiki access
Jim Winkler
Hi Ries,
User name: Jim Winkler
Logging into http://librecad.org/cms/home/get-help/forum.html with  [hidden email] (email, not password) gets me on.
Presumably, it's the same password?
It recognizes "Jim Winkler".
(Going to be gone until tomorrow btw)
Thanks again!
Jim
Date: Wed, 18 Mar 2015 13:40:50 -0700
To: [hidden email]
Jim,
the forum and wiki are not connected for login's because the forum is hosted somewhere else.
to login into the wiki.
Ries
On Mar 18, 2015, at 9:39 PM, Jim Winkler [via LibreCAD] <[hidden email]> wrote:
Hi Ries,
I don't seem to be able to access wiki.librecad.org. I did enter my email on the application as <a href="x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]  I am logged in under the forum.
Thanks!
Jim
From: <a href="x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
Jim,
Ries
To unsubscribe from LibreCAD, <a href="https://" rel="nofollow" target="_blank">click here.
http://forum.librecad.org/Wiki-access-tp5709959p5711224.html
http://forum.librecad.org/Wiki-access-tp5709959p5711225.html
Re: Wiki access
RE: Wiki access
Jim Winkler
Hi Ries,
I requested a password reset for the forum and then attempted to request a password reset for the wiki and got:
  • A password reset email has already been sent, within the last 24 hours. To prevent abuse, only one password reset email will be sent per 24 hours.
I'll try again later and see what happens. If I run into trouble, I'll pester you again.
Thanks for all your help,
Best -Jim
Date: Wed, 18 Mar 2015 14:21:08 -0700
To: [hidden email]
Jim,
both systems use different passwords.
In both cases The system should have been asked for a password.
And I believe both system's do have a password recovery procedure.
Ries
On Mar 18, 2015, at 10:15 PM, Jim Winkler [via LibreCAD] <[hidden email]> wrote:
Hi Ries,
Logging into http://librecad.org/cms/home/get-help/forum.html with  <a href="x-msg://36/user/SendEmail.jtp?type=node&amp;node=5711226&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email] (email, not password) gets me on.
Thanks again!
Jim
From: <a href="x-msg://36/user/SendEmail.jtp?type=node&amp;node=5711226&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="x-msg://36/user/SendEmail.jtp?type=node&amp;node=5711226&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
Jim,
Ries
Hi Ries,
I don't seem to be able to access wiki.librecad.org. I did enter my email on the application as <a href="<a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=0">x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]  I am logged in under the forum.
Thanks!
Jim
From: <a href="<a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=1">x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="<a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=2">x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
Jim,
Ries
To unsubscribe from Wiki access, <a href="https://" target="_blank" rel="nofollow">click here.
http://forum.librecad.org/Wiki-access-tp5709959p5711226.html
http://forum.librecad.org/Wiki-access-tp5709959p5711227.html
RE: Wiki access
Jim Winkler
Hi Ries,
I tried resetting my password from here: http://wiki.librecad.org/index.php/Special:PasswordReset
I never received an email. It's been 12 hours or so. Any other options? Must have mis-entered my email.
Thanks -Jim
To: [hidden email]
Jim,
Ries
Hi Ries,
Thanks again!
Jim
Jim,
Ries
Hi Ries,
Thanks!
Jim
Jim,
Ries
RE: Wiki access
Jim Winkler
Should have added: it did say it sent me a reset "A password reset email has been sent."
Jim
To: [hidden email]
Subject: RE: Wiki access
Date: Sun, 22 Mar 2015 13:32:29 -0700
Hi Ries,
Thanks -Jim
To: [hidden email]
Jim,
Ries
Hi Ries,
Thanks again!
Jim
Jim,
Ries
Hi Ries,
Thanks!
Jim
Jim,
Ries
Re: Wiki access
RE: Wiki access
Jim Winkler
OK, take me off. -Jim
Date: Sun, 22 Mar 2015 14:09:06 -0700
To: [hidden email]
Jim,
I can remove your account from the wiki and you can do a re-signup?
Ries
On Mar 22, 2015, at 9:33 PM, Jim Winkler [via LibreCAD] <[hidden email]> wrote:
Jim
From: <a href="x-msg://51/user/SendEmail.jtp?type=node&amp;node=5711240&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="x-msg://51/user/SendEmail.jtp?type=node&amp;node=5711240&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
Hi Ries,
Thanks -Jim
From: <a href="x-msg://51/user/SendEmail.jtp?type=node&amp;node=5711240&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="x-msg://51/user/SendEmail.jtp?type=node&amp;node=5711240&amp;i=3" target="_top" rel="nofollow" link="external">[hidden email]
Jim,
Ries
Hi Ries,
Logging into http://librecad.org/cms/home/get-help/forum.html with  <a href="<a href="x-msg://36/user/SendEmail.jtp?type=node&amp;amp;node=5711226&amp;amp;i=0">x-msg://36/user/SendEmail.jtp?type=node&amp;node=5711226&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email] (email, not password) gets me on.
Thanks again!
Jim
From: <a href="<a href="x-msg://36/user/SendEmail.jtp?type=node&amp;amp;node=5711226&amp;amp;i=1">x-msg://36/user/SendEmail.jtp?type=node&amp;node=5711226&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="<a href="x-msg://36/user/SendEmail.jtp?type=node&amp;amp;node=5711226&amp;amp;i=2">x-msg://36/user/SendEmail.jtp?type=node&amp;node=5711226&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
Jim,
Ries
Hi Ries,
I don't seem to be able to access wiki.librecad.org. I did enter my email on the application as <a href="<a href="<a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;amp;node=5711224&amp;amp;amp;i=0">x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=0"><a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=0">x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]  I am logged in under the forum.
Thanks!
Jim
From: <a href="<a href="<a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;amp;node=5711224&amp;amp;amp;i=1">x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=1"><a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=1">x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="<a href="<a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;amp;node=5711224&amp;amp;amp;i=2">x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=2"><a href="x-msg://30/user/SendEmail.jtp?type=node&amp;amp;node=5711224&amp;amp;i=2">x-msg://30/user/SendEmail.jtp?type=node&amp;node=5711224&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
Jim,
Ries
http://forum.librecad.org/Wiki-access-tp5709959p5711240.html
http://forum.librecad.org/Wiki-access-tp5709959p5711241.html
Re: Wiki access
Jim Winkler
Hi Ries,
I tried to register as Jim Winkler again, but it appears that the account was not removed. I reapplied as "James Winkler" and jimlibrecad (that symbol) outlook.com.
I confirmed on April 11th but have not received a confirmation.
Thanks again! Jim
Re: Wiki access
Re: Wiki access
Jim Winkler
When I do a "reset password", I don't get an email. Checked spam folder too. Must have mis-entered my email. My James Winkler account has been approved. Shall I use it? Thanks -Jim
12
