bevel length 1 and 2 given angled length
3 messages Options Options
phreakk36
I am drawing a blank as to how to enter the dimensions for a bevel when have the angled bevel length.  I have a length of 13.488 and a width of 14.88 with a bevel length of 7.906 please see attached.  I am trying to get the "straight bevel" that is in the image and not the rounded corners or radius that can be added "if needed"
Re: bevel length 1 and 2 given angled length
It is not possible to use the angled bevel length as input directly. Assuming you want a 45° bevel on lines meeting at 90°, the input for bevel length 1 and 2  would be: x/sqrt2 , x being your desired angled bevel length. But it doesn't work, or I don't know the proper syntax. Somebody else?
It works if you type in the value for square root of 2 manually with an accuracy you think is sufficient, 1.4142135...
phreakk36
Thank you so much!!!! I was able to get the angled length to 7.9061.
