Hi I am new and am trying to build from source. I am getting errors. Can someone help?
I downloaded source code from github. I tried to follow the instruction here https://github.com/LibreCAD/LibreCAD/wiki/Build-from-source It worked until make -j4. I also tried build-osx.sh and building from qt-creator, both didn't work. Here is the output from make -j4: cd libraries/ && ( test -e Makefile || /Users/karenlaw/anaconda3/bin/qmake -o Makefile /Users/karenlaw/dev/LibreCAD-master/libraries/libraries.pro -spec macx-g++ ) && /Applications/Xcode.app/Contents/Developer/usr/bin/make -f Makefile cd libdxfrw/ && ( test -e Makefile || /Users/karenlaw/anaconda3/bin/qmake -o Makefile /Users/karenlaw/dev/LibreCAD-master/libraries/libdxfrw/libdxfrw.pro -spec macx-g++ ) && /Applications/Xcode.app/Contents/Developer/usr/bin/make -f Makefile cd muparser/ && ( test -e Makefile || /Users/karenlaw/anaconda3/bin/qmake -o Makefile /Users/karenlaw/dev/LibreCAD-master/libraries/muparser/muparser.pro -spec macx-g++ ) && /Applications/Xcode.app/Contents/Developer/usr/bin/make -f Makefile cd jwwlib/ && ( test -e Makefile || /Users/karenlaw/anaconda3/bin/qmake -o Makefile /Users/karenlaw/dev/LibreCAD-master/libraries/jwwlib/jwwlib.pro -spec macx-g++ ) && /Applications/Xcode.app/Contents/Developer/usr/bin/make -f Makefile /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -Iinclude -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/muparser/obj/muParserTokenReader.o src/muParserTokenReader.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/libdxfrw.o src/libdxfrw.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/lib/jwwlib/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/jwwlib/obj/dl_writer_ascii.o src/dl_writer_ascii.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -Iinclude -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/muparser/obj/muParserError.o src/muParserError.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/lib/jwwlib/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/jwwlib/obj/dl_jww.o src/dl_jww.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/libdwgr.o src/libdwgr.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -Iinclude -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/muparser/obj/muParserCallback.o src/muParserCallback.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -Iinclude -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/muparser/obj/muParserBytecode.o src/muParserBytecode.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/lib/jwwlib/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/jwwlib/obj/jwwdoc.o src/jwwdoc.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -Iinclude -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/muparser/obj/muParserBase.o src/muParserBase.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/drw_header.o src/drw_header.cpp rm -f ../../generated/lib/libjwwlib.a /Library/Developer/CommandLineTools/usr/bin/ar cq ../../generated/lib/libjwwlib.a ../../generated/lib/jwwlib/obj/dl_writer_ascii.o ../../generated/lib/jwwlib/obj/dl_jww.o ../../generated/lib/jwwlib/obj/jwwdoc.o /Library/Developer/CommandLineTools/usr/bin/ranlib -s ../../generated/lib/libjwwlib.a /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -Iinclude -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/muparser/obj/muParser.o src/muParser.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/drw_classes.o src/drw_classes.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/drw_entities.o src/drw_entities.cpp rm -f ../../generated/lib/libmuparser.a /Library/Developer/CommandLineTools/usr/bin/ar cq ../../generated/lib/libmuparser.a ../../generated/lib/muparser/obj/muParserTokenReader.o ../../generated/lib/muparser/obj/muParserError.o ../../generated/lib/muparser/obj/muParserCallback.o ../../generated/lib/muparser/obj/muParserBytecode.o ../../generated/lib/muparser/obj/muParserBase.o ../../generated/lib/muparser/obj/muParser.o /Library/Developer/CommandLineTools/usr/bin/ranlib -s ../../generated/lib/libmuparser.a /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/drw_objects.o src/drw_objects.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/drw_textcodec.o src/intern/drw_textcodec.cpp src/drw_objects.cpp:1221:79: warning: unused parameter 'bs' [-Wunused-parameter] bool DRW_PlotSettings::parseDwg(DRW::Version version, dwgBuffer *buf, duint32 bs){ ^ /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dxfreader.o src/intern/dxfreader.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dxfwriter.o src/intern/dxfwriter.cpp 1 warning generated. /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgreader.o src/intern/dwgreader.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgbuffer.o src/intern/dwgbuffer.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/drw_dbg.o src/intern/drw_dbg.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgreader21.o src/intern/dwgreader21.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgreader18.o src/intern/dwgreader18.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgreader15.o src/intern/dwgreader15.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgutil.o src/intern/dwgutil.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/rscodec.o src/intern/rscodec.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgreader27.o src/intern/dwgreader27.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -std=c++11 -O2 -fPIC -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -DQT_NO_DEBUG -I. -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/lib/libdxfrw/obj/dwgreader24.o src/intern/dwgreader24.cpp rm -f ../../generated/lib/libdxfrw.a /Library/Developer/CommandLineTools/usr/bin/ar cq ../../generated/lib/libdxfrw.a ../../generated/lib/libdxfrw/obj/libdxfrw.o ../../generated/lib/libdxfrw/obj/libdwgr.o ../../generated/lib/libdxfrw/obj/drw_header.o ../../generated/lib/libdxfrw/obj/drw_classes.o ../../generated/lib/libdxfrw/obj/drw_entities.o ../../generated/lib/libdxfrw/obj/drw_objects.o ../../generated/lib/libdxfrw/obj/drw_textcodec.o ../../generated/lib/libdxfrw/obj/dxfreader.o ../../generated/lib/libdxfrw/obj/dxfwriter.o ../../generated/lib/libdxfrw/obj/dwgreader.o ../../generated/lib/libdxfrw/obj/dwgbuffer.o ../../generated/lib/libdxfrw/obj/drw_dbg.o ../../generated/lib/libdxfrw/obj/dwgreader21.o ../../generated/lib/libdxfrw/obj/dwgreader18.o ../../generated/lib/libdxfrw/obj/dwgreader15.o ../../generated/lib/libdxfrw/obj/dwgutil.o ../../generated/lib/libdxfrw/obj/rscodec.o ../../generated/lib/libdxfrw/obj/dwgreader27.o ../../generated/lib/libdxfrw/obj/dwgreader24.o /Library/Developer/CommandLineTools/usr/bin/ranlib -s ../../generated/lib/libdxfrw.a cd librecad/ && ( test -e Makefile || /Users/karenlaw/anaconda3/bin/qmake -o Makefile /Users/karenlaw/dev/LibreCAD-master/librecad/librecad.pro -spec macx-g++ ) && /Applications/Xcode.app/Contents/Developer/usr/bin/make -f Makefile cd src/ && ( test -e Makefile || /Users/karenlaw/anaconda3/bin/qmake -o Makefile /Users/karenlaw/dev/LibreCAD-master/librecad/src/src.pro -spec macx-g++ ) && /Applications/Xcode.app/Contents/Developer/usr/bin/make -f Makefile /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_commandwidget.ui -o ../../generated/librecad/ui/ui_qg_commandwidget.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_arcoptions.ui -o ../../generated/librecad/ui/ui_qg_arcoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_arctangentialoptions.ui -o ../../generated/librecad/ui/ui_qg_arctangentialoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_beveloptions.ui -o ../../generated/librecad/ui/ui_qg_beveloptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_blockdialog.ui -o ../../generated/librecad/ui/ui_qg_blockdialog.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_circleoptions.ui -o ../../generated/librecad/ui/ui_qg_circleoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_circletan2options.ui -o ../../generated/librecad/ui/ui_qg_circletan2options.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_coordinatewidget.ui -o ../../generated/librecad/ui/ui_qg_coordinatewidget.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dimensionlabeleditor.ui -o ../../generated/librecad/ui/ui_qg_dimensionlabeleditor.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dimlinearoptions.ui -o ../../generated/librecad/ui/ui_qg_dimlinearoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dimoptions.ui -o ../../generated/librecad/ui/ui_qg_dimoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_widgetpen.ui -o ../../generated/librecad/ui/ui_qg_widgetpen.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlghatch.ui -o ../../generated/librecad/ui/ui_qg_dlghatch.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlginitial.ui -o ../../generated/librecad/ui/ui_qg_dlginitial.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgimageoptions.ui -o ../../generated/librecad/ui/ui_qg_dlgimageoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgmirror.ui -o ../../generated/librecad/ui/ui_qg_dlgmirror.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgmove.ui -o ../../generated/librecad/ui/ui_qg_dlgmove.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgmoverotate.ui -o ../../generated/librecad/ui/ui_qg_dlgmoverotate.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgmtext.ui -o ../../generated/librecad/ui/ui_qg_dlgmtext.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgoptionsdrawing.ui -o ../../generated/librecad/ui/ui_qg_dlgoptionsdrawing.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgoptionsgeneral.ui -o ../../generated/librecad/ui/ui_qg_dlgoptionsgeneral.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgoptionsmakercam.ui -o ../../generated/librecad/ui/ui_qg_dlgoptionsmakercam.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgpoint.ui -o ../../generated/librecad/ui/ui_qg_dlgpoint.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgpolyline.ui -o ../../generated/librecad/ui/ui_qg_dlgpolyline.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgrotate.ui -o ../../generated/librecad/ui/ui_qg_dlgrotate.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgrotate2.ui -o ../../generated/librecad/ui/ui_qg_dlgrotate2.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgscale.ui -o ../../generated/librecad/ui/ui_qg_dlgscale.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgspline.ui -o ../../generated/librecad/ui/ui_qg_dlgspline.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_dlgtext.ui -o ../../generated/librecad/ui/ui_qg_dlgtext.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_exitdialog.ui -o ../../generated/librecad/ui/ui_qg_exitdialog.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_imageoptions.ui -o ../../generated/librecad/ui/ui_qg_imageoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_insertoptions.ui -o ../../generated/librecad/ui/ui_qg_insertoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_layerdialog.ui -o ../../generated/librecad/ui/ui_qg_layerdialog.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_libraryinsertoptions.ui -o ../../generated/librecad/ui/ui_qg_libraryinsertoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_lineangleoptions.ui -o ../../generated/librecad/ui/ui_qg_lineangleoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_linebisectoroptions.ui -o ../../generated/librecad/ui/ui_qg_linebisectoroptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_lineoptions.ui -o ../../generated/librecad/ui/ui_qg_lineoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_lineparalleloptions.ui -o ../../generated/librecad/ui/ui_qg_lineparalleloptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_lineparallelthroughoptions.ui -o ../../generated/librecad/ui/ui_qg_lineparallelthroughoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_linepolygon2options.ui -o ../../generated/librecad/ui/ui_qg_linepolygon2options.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_linepolygonoptions.ui -o ../../generated/librecad/ui/ui_qg_linepolygonoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_linerelangleoptions.ui -o ../../generated/librecad/ui/ui_qg_linerelangleoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_modifyoffsetoptions.ui -o ../../generated/librecad/ui/ui_qg_modifyoffsetoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_mousewidget.ui -o ../../generated/librecad/ui/ui_qg_mousewidget.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_moverotateoptions.ui -o ../../generated/librecad/ui/ui_qg_moverotateoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_mtextoptions.ui -o ../../generated/librecad/ui/ui_qg_mtextoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_polylineoptions.ui -o ../../generated/librecad/ui/ui_qg_polylineoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_polylineequidistantoptions.ui -o ../../generated/librecad/ui/ui_qg_polylineequidistantoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_printpreviewoptions.ui -o ../../generated/librecad/ui/ui_qg_printpreviewoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_roundoptions.ui -o ../../generated/librecad/ui/ui_qg_roundoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_selectionwidget.ui -o ../../generated/librecad/ui/ui_qg_selectionwidget.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_snapdistoptions.ui -o ../../generated/librecad/ui/ui_qg_snapdistoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_snapmiddleoptions.ui -o ../../generated/librecad/ui/ui_qg_snapmiddleoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_splineoptions.ui -o ../../generated/librecad/ui/ui_qg_splineoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_textoptions.ui -o ../../generated/librecad/ui/ui_qg_textoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_trimamountoptions.ui -o ../../generated/librecad/ui/ui_qg_trimamountoptions.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_snaptoolbar.ui -o ../../generated/librecad/ui/ui_qg_snaptoolbar.h /Users/karenlaw/anaconda3/bin/uic ui/forms/qg_activelayername.ui -o ../../generated/librecad/ui/ui_qg_activelayername.h /Users/karenlaw/anaconda3/bin/uic ui/forms/lc_dlgsplinepoints.ui -o ../../generated/librecad/ui/ui_lc_dlgsplinepoints.h /Users/karenlaw/anaconda3/bin/uic ui/forms/lc_widgetoptionsdialog.ui -o ../../generated/librecad/ui/ui_lc_widgetoptionsdialog.h /Users/karenlaw/anaconda3/bin/uic ui/lc_deviceoptions.ui -o ../../generated/librecad/ui/ui_lc_deviceoptions.h /Users/karenlaw/anaconda3/bin/uic ui/generic/comboboxoption.ui -o ../../generated/librecad/ui/ui_comboboxoption.h /Users/karenlaw/anaconda3/bin/uic ui/generic/widgetcreator.ui -o ../../generated/librecad/ui/ui_widgetcreator.h /Users/karenlaw/anaconda3/bin/uic ui/generic/colorwizard.ui -o ../../generated/librecad/ui/ui_colorwizard.h /Users/karenlaw/anaconda3/bin/uic ui/generic/textfileviewer.ui -o ../../generated/librecad/ui/ui_textfileviewer.h /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_actioninterface.o lib/actions/rs_actioninterface.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_preview.o lib/actions/rs_preview.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_previewactioninterface.o lib/actions/rs_previewactioninterface.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_snapper.o lib/actions/rs_snapper.cpp In file included from lib/actions/rs_snapper.cpp:35: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:31: lib/gui/rs_dialogfactoryinterface.h:389:59: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] virtual void updateMouseWidget(const QString& = QString::null, ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_snapper.cpp:35: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:31: lib/gui/rs_dialogfactoryinterface.h:390:38: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] const QString& = QString::null)=0; ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_snapper.cpp:35: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:32: In file included from lib/engine/rs_block.h:31: lib/engine/rs_document.h:65:18: warning: 'isDocument' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual bool isDocument() const { ^ lib/engine/rs_entity.h:187:18: note: overridden virtual function is here virtual bool isDocument() const { ^ In file included from lib/actions/rs_snapper.cpp:35: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:32: In file included from lib/engine/rs_block.h:31: lib/engine/rs_document.h:73:18: warning: 'removeUndoable' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void removeUndoable(RS_Undoable* u) { ^ lib/engine/rs_undo.h:68:18: note: overridden virtual function is here virtual void removeUndoable(RS_Undoable* u) = 0; ^ In file included from lib/actions/rs_preview.cpp:32: lib/engine/rs_settings.h:90:55: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] const QString& def = QString::null, ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_preview.cpp:32: lib/engine/rs_settings.h:93:55: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] const QString& def = QString::null, ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_actioninterface.cpp:31: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:31: lib/gui/rs_dialogfactoryinterface.h:389:59: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] virtual void updateMouseWidget(const QString& = QString::null, ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_actioninterface.cpp:31: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:31: lib/gui/rs_dialogfactoryinterface.h:390:38: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] const QString& = QString::null)=0; ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_actioninterface.cpp:31: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:32: In file included from lib/engine/rs_block.h:31: lib/engine/rs_document.h:65:18: warning: 'isDocument' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual bool isDocument() const { ^ lib/engine/rs_entity.h:187:18: note: overridden virtual function is here virtual bool isDocument() const { ^ In file included from lib/actions/rs_actioninterface.cpp:31: In file included from lib/gui/rs_dialogfactory.h:31: In file included from lib/gui/rs_dialogfactoryadapter.h:32: In file included from lib/engine/rs_block.h:31: lib/engine/rs_document.h:73:18: warning: 'removeUndoable' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void removeUndoable(RS_Undoable* u) { ^ lib/engine/rs_undo.h:68:18: note: overridden virtual function is here virtual void removeUndoable(RS_Undoable* u) = 0; ^ In file included from lib/actions/rs_snapper.cpp:38: lib/engine/rs_settings.h:90:55: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] const QString& def = QString::null, ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ In file included from lib/actions/rs_snapper.cpp:38: lib/engine/rs_settings.h:93:55: warning: 'null' is deprecated: use QString() [-Wdeprecated-declarations] const QString& def = QString::null, ^ /usr/local/include/QtCore/qstring.h:912:5: note: 'null' has been explicitly marked deprecated here QT_DEPRECATED_X("use QString()") ^ /usr/local/include/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X' # define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text) ^ /usr/local/include/QtCore/qcompilerdetection.h:643:55: note: expanded from macro 'Q_DECL_DEPRECATED_X' # define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text))) ^ /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_creation.o lib/creation/rs_creation.cpp 4 warnings generated. 2 warnings generated. /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_debug.o lib/debug/rs_debug.cpp /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_arc.o lib/engine/rs_arc.cpp In file included from lib/creation/rs_creation.cpp:28: In file included from ../../../../anaconda3/include/qt/QtCore/QString:1: ../../../../anaconda3/include/qt/QtCore/qstring.h:862:26: error: no template named 'QConditional' in namespace 'QtPrivate'; did you mean 'std::conditional'? typedef typename QtPrivate::QConditional<isUnsigned, qulonglong, qlonglong>::Type Int64; ^~~~~~~~~~~~~~~~~~~~~~~ std::conditional /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/type_traits:429:33: note: 'std::conditional' declared here struct _LIBCPP_TEMPLATE_VIS conditional {typedef _If type;}; ^ In file included from lib/creation/rs_creation.cpp:28: In file included from ../../../../anaconda3/include/qt/QtCore/QString:1: ../../../../anaconda3/include/qt/QtCore/qstring.h:863:26: error: no template named 'QConditional' in namespace 'QtPrivate'; did you mean 'std::conditional'? typedef typename QtPrivate::QConditional<isUnsigned, uint, int>::Type Int32; ^~~~~~~~~~~~~~~~~~~~~~~ std::conditional /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/type_traits:429:33: note: 'std::conditional' declared here struct _LIBCPP_TEMPLATE_VIS conditional {typedef _If type;}; ^ 6 warnings generated. /Library/Developer/CommandLineTools/usr/bin/g++ -c -pipe -g -O2 -std=gnu++11 -arch x86_64 -isysroot /Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.10 -Wall -W -fPIC -DDWGSUPPORT -DQC_APPDIR="LibreCAD" -DLC_VERSION="2.2.0-alpha" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I. -I/usr/local/include -I../../libraries/muparser/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/generators -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/printing -Iactions -Imain -Imain/console_dxf2pdf -Itest -Iplugins -Iui -Iui/forms -Iui/generic -I../res -I../../../../anaconda3/include/qt -I../../../../anaconda3/include/qt/QtSvg -I../../../../anaconda3/include/qt/QtPrintSupport -I../../../../anaconda3/include/qt/QtWidgets -I../../../../anaconda3/include/qt/QtGui -I../../../../anaconda3/include/qt/QtCore -I../../generated/librecad/moc -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers -I/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/AGL.framework/Headers -I../../generated/librecad/ui -I../../../../anaconda3/mkspecs/macx-g++ -o ../../generated/librecad/obj/rs_block.o lib/engine/rs_block.cpp In file included from lib/creation/rs_creation.cpp:29: In file included from ../../../../anaconda3/include/qt/QtCore/QFileInfo:1: In file included from ../../../../anaconda3/include/qt/QtCore/qfileinfo.h:43: In file included from /usr/local/include/QtCore/qfile.h:44: In file included from /usr/local/include/QtCore/qfiledevice.h:43: In file included from /usr/local/include/QtCore/qiodevice.h:45: In file included from /usr/local/include/QtCore/qobject.h:49: In file included from /usr/local/include/QtCore/qlist.h:47: /usr/local/include/QtCore/qhashfunctions.h:103:47: error: unknown type name 'QStringView' Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qHash(QStringView key, uint seed = 0) noexcept; ^ /usr/local/include/QtCore/qhashfunctions.h:106:49: error: unknown type name 'QStringView' Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qt_hash(QStringView key, uint chained = 0) noexcept; ^ /usr/local/include/QtCore/qhashfunctions.h:206:47: error: no member named 'QStringView' in the global namespace QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH_BY_VALUE(QStringView) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~ /usr/local/include/QtCore/qhashfunctions.h:202:42: note: expanded from macro 'QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH_BY_VALUE' QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH(Class, argument_type) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~ /usr/local/include/QtCore/qhashfunctions.h:180:43: note: expanded from macro 'QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH' struct hash< QT_PREPEND_NAMESPACE(Class) > { \ ~~~~~~~~~~~~~~~~~~~~~^~~~~~ /usr/local/include/QtCore/qglobal.h:146:39: note: expanded from macro 'QT_PREPEND_NAMESPACE' # define QT_PREPEND_NAMESPACE(name) ::name ~~^ In file included from lib/creation/rs_creation.cpp:29: In file included from ../../../../anaconda3/include/qt/QtCore/QFileInfo:1: In file included from ../../../../anaconda3/include/qt/QtCore/qfileinfo.h:43: In file included from /usr/local/include/QtCore/qfile.h:44: In file included from /usr/local/include/QtCore/qfiledevice.h:43: In file included from /usr/local/include/QtCore/qiodevice.h:45: In file included from /usr/local/include/QtCore/qobject.h:49: In file included from /usr/local/include/QtCore/qlist.h:48: /usr/local/include/QtCore/qvector.h:1134:15: error: use of undeclared identifier 'QStringView' QVector<uint> QStringView::toUcs4() const { return QtPrivate::convertToUcs4(*this); } ^ /usr/local/include/QtCore/qvector.h:1136:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(const QString &sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1137:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior), cs); } ^ /usr/local/include/QtCore/qvector.h:1138:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(QChar sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1139:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior), cs); } ^ /usr/local/include/QtCore/qvector.h:1141:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(const QRegExp &sep, Qt::SplitBehavior behavior) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1142:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior)); } ^ /usr/local/include/QtCore/qvector.h:1145:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(const QRegularExpression &sep, Qt::SplitBehavior behavior) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1146:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior)); } ^ /usr/local/include/QtCore/qvector.h:1148:33: error: out-of-line definition of 'split' does not match any declaration in 'QStringRef' QVector<QStringRef> QStringRef::split(const QString &sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~ /usr/local/include/QtCore/qvector.h:1149:30: error: no member named '_sb' in 'QString' { return split(sep, QString::_sb(behavior), cs); } ~~~~~~~~~^ /usr/local/include/QtCore/qvector.h:1150:33: error: out-of-line definition of 'split' does not match any declaration in 'QStringRef' QVector<QStringRef> QStringRef::split(QChar sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~ /usr/local/include/QtCore/qvector.h:1151:30: error: no member named '_sb' in 'QString' { return split(sep, QString::_sb(behavior), cs); } ~~~~~~~~~^ In file included from lib/creation/rs_creation.cpp:29: In file included from ../../../../anaconda3/include/qt/QtCore/QFileInfo:1: In file included from ../../../../anaconda3/include/qt/QtCore/qfileinfo.h:43: In file included from /usr/local/include/QtCore/qfile.h:44: In file included from /usr/local/include/QtCore/qfiledevice.h:43: In file included from /usr/local/include/QtCore/qiodevice.h:45: In file included from /usr/local/include/QtCore/qobject.h:49: In file included from /usr/local/include/QtCore/qlist.h:1179: In file included from /usr/local/include/QtCore/qstringlist.h:50: In file included from /usr/local/include/QtCore/qstringmatcher.h:45: In file included from /usr/local/include/QtCore/qstringview.h:49: /usr/local/include/QtCore/qstringliteral.h:64:9: warning: 'QT_UNICODE_LITERAL' macro redefined [-Wmacro-redefined] #define QT_UNICODE_LITERAL(str) u"" str ^ ../../../../anaconda3/include/qt/QtCore/qstring.h:173:9: note: previous definition is here #define QT_UNICODE_LITERAL(str) QT_UNICODE_LITERAL_II(str) ^ In file included from lib/creation/rs_creation.cpp:29: In file included from ../../../../anaconda3/include/qt/QtCore/QFileInfo:1: In file included from ../../../../anaconda3/include/qt/QtCore/qfileinfo.h:43: In file included from /usr/local/include/QtCore/qfile.h:44: In file included from /usr/local/include/QtCore/qfiledevice.h:43: In file included from /usr/local/include/QtCore/qiodevice.h:45: In file included from /usr/local/include/QtCore/qobject.h:49: In file included from /usr/local/include/QtCore/qlist.h:1179: In file included from /usr/local/include/QtCore/qstringlist.h:50: In file included from /usr/local/include/QtCore/qstringmatcher.h:45: In file included from /usr/local/include/QtCore/qstringview.h:49: /usr/local/include/QtCore/qstringliteral.h:65:9: warning: 'QStringLiteral' macro redefined [-Wmacro-redefined] #define QStringLiteral(str) \ ^ ../../../../anaconda3/include/qt/QtCore/qstring.h:174:9: note: previous definition is here #define QStringLiteral(str) \ ^ In file included from lib/creation/rs_creation.cpp:29: In file included from ../../../../anaconda3/include/qt/QtCore/QFileInfo:1: In file included from ../../../../anaconda3/include/qt/QtCore/qfileinfo.h:43: In file included from /usr/local/include/QtCore/qfile.h:44: In file included from /usr/local/include/QtCore/qfiledevice.h:43: In file included from /usr/local/include/QtCore/qiodevice.h:45: In file included from /usr/local/include/QtCore/qobject.h:49: In file included from /usr/local/include/QtCore/qlist.h:1179: In file included from /usr/local/include/QtCore/qstringlist.h:50: In file included from /usr/local/include/QtCore/qstringmatcher.h:45: In file included from /usr/local/include/QtCore/qstringview.h:49: /usr/local/include/QtCore/qstringliteral.h:90:8: error: redefinition of 'QStaticStringData' struct QStaticStringData ^ ../../../../anaconda3/include/qt/QtCore/qstring.h:195:8: note: previous definition is here struct QStaticStringData ^ fatal error: too many errors emitted, stopping now [-ferror-limit=] In file included from lib/debug/rs_debug.cpp:33: In file included from ../../../../anaconda3/include/qt/QtCore/QString:1: ../../../../anaconda3/include/qt/QtCore/qstring.h:862:26: error: no template named 'QConditional' in namespace 'QtPrivate'; did you mean 'std::conditional'? typedef typename QtPrivate::QConditional<isUnsigned, qulonglong, qlonglong>::Type Int64; ^~~~~~~~~~~~~~~~~~~~~~~ std::conditional /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/type_traits:429:33: note: 'std::conditional' declared here struct _LIBCPP_TEMPLATE_VIS conditional {typedef _If type;}; ^ In file included from lib/debug/rs_debug.cpp:33: In file included from ../../../../anaconda3/include/qt/QtCore/QString:1: ../../../../anaconda3/include/qt/QtCore/qstring.h:863:26: error: no template named 'QConditional' in namespace 'QtPrivate'; did you mean 'std::conditional'? typedef typename QtPrivate::QConditional<isUnsigned, uint, int>::Type Int32; ^~~~~~~~~~~~~~~~~~~~~~~ std::conditional /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/type_traits:429:33: note: 'std::conditional' declared here struct _LIBCPP_TEMPLATE_VIS conditional {typedef _If type;}; ^ In file included from lib/debug/rs_debug.cpp:35: In file included from ../../../../anaconda3/include/qt/QtCore/QDateTime:1: In file included from ../../../../anaconda3/include/qt/QtCore/qdatetime.h:46: In file included from /usr/local/include/QtCore/qshareddata.h:46: In file included from /usr/local/include/QtCore/qhash.h:46: In file included from /usr/local/include/QtCore/qlist.h:47: /usr/local/include/QtCore/qhashfunctions.h:103:47: error: unknown type name 'QStringView' Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qHash(QStringView key, uint seed = 0) noexcept; ^ /usr/local/include/QtCore/qhashfunctions.h:106:49: error: unknown type name 'QStringView' Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qt_hash(QStringView key, uint chained = 0) noexcept; ^ /usr/local/include/QtCore/qhashfunctions.h:206:47: error: no member named 'QStringView' in the global namespace QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH_BY_VALUE(QStringView) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~ /usr/local/include/QtCore/qhashfunctions.h:202:42: note: expanded from macro 'QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH_BY_VALUE' QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH(Class, argument_type) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~ /usr/local/include/QtCore/qhashfunctions.h:180:43: note: expanded from macro 'QT_SPECIALIZE_STD_HASH_TO_CALL_QHASH' struct hash< QT_PREPEND_NAMESPACE(Class) > { \ ~~~~~~~~~~~~~~~~~~~~~^~~~~~ /usr/local/include/QtCore/qglobal.h:146:39: note: expanded from macro 'QT_PREPEND_NAMESPACE' # define QT_PREPEND_NAMESPACE(name) ::name ~~^ In file included from lib/debug/rs_debug.cpp:35: In file included from ../../../../anaconda3/include/qt/QtCore/QDateTime:1: In file included from ../../../../anaconda3/include/qt/QtCore/qdatetime.h:46: In file included from /usr/local/include/QtCore/qshareddata.h:46: In file included from /usr/local/include/QtCore/qhash.h:46: In file included from /usr/local/include/QtCore/qlist.h:48: /usr/local/include/QtCore/qvector.h:1134:15: error: use of undeclared identifier 'QStringView' QVector<uint> QStringView::toUcs4() const { return QtPrivate::convertToUcs4(*this); } ^ /usr/local/include/QtCore/qvector.h:1136:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(const QString &sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1137:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior), cs); } ^ /usr/local/include/QtCore/qvector.h:1138:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(QChar sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1139:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior), cs); } ^ /usr/local/include/QtCore/qvector.h:1141:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(const QRegExp &sep, Qt::SplitBehavior behavior) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1142:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior)); } ^ /usr/local/include/QtCore/qvector.h:1145:30: error: out-of-line definition of 'splitRef' does not match any declaration in 'QString' QVector<QStringRef> QString::splitRef(const QRegularExpression &sep, Qt::SplitBehavior behavior) const ^~~~~~~~ /usr/local/include/QtCore/qvector.h:1146:24: error: use of undeclared identifier '_sb' { return splitRef(sep, _sb(behavior)); } ^ /usr/local/include/QtCore/qvector.h:1148:33: error: out-of-line definition of 'split' does not match any declaration in 'QStringRef' QVector<QStringRef> QStringRef::split(const QString &sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~ /usr/local/include/QtCore/qvector.h:1149:30: error: no member named '_sb' in 'QString' { return split(sep, QString::_sb(behavior), cs); } ~~~~~~~~~^ /usr/local/include/QtCore/qvector.h:1150:33: error: out-of-line definition of 'split' does not match any declaration in 'QStringRef' QVector<QStringRef> QStringRef::split(QChar sep, Qt::SplitBehavior behavior, Qt::CaseSensitivity cs) const ^~~~~ /usr/local/include/QtCore/qvector.h:1151:30: error: no member named '_sb' in 'QString' { return split(sep, QString::_sb(behavior), cs); } ~~~~~~~~~^ In file included from lib/debug/rs_debug.cpp:35: In file included from ../../../../anaconda3/include/qt/QtCore/QDateTime:1: In file included from ../../../../anaconda3/include/qt/QtCore/qdatetime.h:46: In file included from /usr/local/include/QtCore/qshareddata.h:46: In file included from /usr/local/include/QtCore/qhash.h:46: In file included from /usr/local/include/QtCore/qlist.h:1179: In file included from /usr/local/include/QtCore/qstringlist.h:50: In file included from /usr/local/include/QtCore/qstringmatcher.h:45: In file included from /usr/local/include/QtCore/qstringview.h:49: /usr/local/include/QtCore/qstringliteral.h:64:9: warning: 'QT_UNICODE_LITERAL' macro redefined [-Wmacro-redefined] #define QT_UNICODE_LITERAL(str) u"" str ^ ../../../../anaconda3/include/qt/QtCore/qstring.h:173:9: note: previous definition is here #define QT_UNICODE_LITERAL(str) QT_UNICODE_LITERAL_II(str) ^ In file included from lib/debug/rs_debug.cpp:35: In file included from ../../../../anaconda3/include/qt/QtCore/QDateTime:1: In file included from ../../../../anaconda3/include/qt/QtCore/qdatetime.h:46: In file included from /usr/local/include/QtCore/qshareddata.h:46: In file included from /usr/local/include/QtCore/qhash.h:46: In file included from /usr/local/include/QtCore/qlist.h:1179: In file included from /usr/local/include/QtCore/qstringlist.h:50: In file included from /usr/local/include/QtCore/qstringmatcher.h:45: In file included from /usr/local/include/QtCore/qstringview.h:49: /usr/local/include/QtCore/qstringliteral.h:65:9: warning: 'QStringLiteral' macro redefined [-Wmacro-redefined] #define QStringLiteral(str) \ ^ ../../../../anaconda3/include/qt/QtCore/qstring.h:174:9: note: previous definition is here #define QStringLiteral(str) \ ^ In file included from lib/debug/rs_debug.cpp:35: In file included from ../../../../anaconda3/include/qt/QtCore/QDateTime:1: In file included from ../../../../anaconda3/include/qt/QtCore/qdatetime.h:46: In file included from /usr/local/include/QtCore/qshareddata.h:46: In file included from /usr/local/include/QtCore/qhash.h:46: In file included from /usr/local/include/QtCore/qlist.h:1179: In file included from /usr/local/include/QtCore/qstringlist.h:50: In file included from /usr/local/include/QtCore/qstringmatcher.h:45: In file included from /usr/local/include/QtCore/qstringview.h:49: /usr/local/include/QtCore/qstringliteral.h:90:8: error: redefinition of 'QStaticStringData' struct QStaticStringData ^ ../../../../anaconda3/include/qt/QtCore/qstring.h:195:8: note: previous definition is here struct QStaticStringData ^ fatal error: too many errors emitted, stopping now [-ferror-limit=] 2 warnings and 20 errors generated. make[2]: *** [../../generated/librecad/obj/rs_creation.o] Error 1 make[2]: *** Waiting for unfinished jobs.... 2 warnings and 20 errors generated. make[2]: *** [../../generated/librecad/obj/rs_debug.o] Error 1 In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:70:21: warning: 'clone' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Entity* clone() const; ^ lib/engine/rs_entity.h:69:21: note: overridden virtual function is here virtual RS_Entity* clone() const = 0; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:75:29: warning: 'rtti' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS2::EntityType rtti() const { ^ lib/engine/rs_entity.h:82:26: note: overridden virtual function is here virtual RS2::EntityType rtti() const{ ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:103:26: warning: 'getQuadratic' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual LC_Quadratic getQuadratic() const; ^ lib/engine/rs_entity.h:535:26: note: overridden virtual function is here virtual LC_Quadratic getQuadratic() const; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:104:23: warning: 'getMiddlePoint' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Vector getMiddlePoint(void) const; ^ lib/engine/rs_entity.h:336:23: note: overridden virtual function is here virtual RS_Vector getMiddlePoint(void)const{ ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:105:23: warning: 'getNearestEndpoint' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Vector getNearestEndpoint(const RS_Vector& coord, ^ lib/engine/rs_entity.h:291:23: note: overridden virtual function is here virtual RS_Vector getNearestEndpoint(const RS_Vector& coord, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:107:23: warning: 'getNearestPointOnEntity' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Vector getNearestPointOnEntity(const RS_Vector& coord, ^ lib/engine/rs_entity.h:305:23: note: overridden virtual function is here virtual RS_Vector getNearestPointOnEntity(const RS_Vector& /*coord*/, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:109:23: warning: 'getNearestCenter' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Vector getNearestCenter(const RS_Vector& coord, ^ lib/engine/rs_atomicentity.h:105:14: note: overridden virtual function is here RS_Vector getNearestCenter(const RS_Vector& /*coord*/, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:111:23: warning: 'getNearestMiddle' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Vector getNearestMiddle(const RS_Vector& coord, ^ lib/engine/rs_entity.h:339:23: note: overridden virtual function is here virtual RS_Vector getNearestMiddle(const RS_Vector& coord, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:114:23: warning: 'getNearestDist' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual RS_Vector getNearestDist(double distance, ^ lib/engine/rs_entity.h:357:23: note: overridden virtual function is here virtual RS_Vector getNearestDist(double distance, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:117:20: warning: 'getDistanceToPoint' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual double getDistanceToPoint(const RS_Vector& coord, ^ lib/engine/rs_entity.h:422:20: note: overridden virtual function is here virtual double getDistanceToPoint(const RS_Vector& coord, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:122:18: warning: 'move' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void move(const RS_Vector& offset); ^ lib/engine/rs_entity.h:450:18: note: overridden virtual function is here virtual void move(const RS_Vector& offset) = 0; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:123:18: warning: 'rotate' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void rotate(const RS_Vector& center, const double& angle); ^ lib/engine/rs_entity.h:456:18: note: overridden virtual function is here virtual void rotate(const RS_Vector& center, const double& angle) = 0; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:124:18: warning: 'rotate' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void rotate(const RS_Vector& center, const RS_Vector& angleVector); ^ lib/engine/rs_entity.h:457:18: note: overridden virtual function is here virtual void rotate(const RS_Vector& center, const RS_Vector& angleVector) = 0; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:125:18: warning: 'scale' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void scale(const RS_Vector& center, const RS_Vector& factor); ^ lib/engine/rs_entity.h:462:18: note: overridden virtual function is here virtual void scale(const RS_Vector& center, const RS_Vector& factor) = 0; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:126:18: warning: 'mirror' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void mirror(const RS_Vector& axisPoint1, const RS_Vector& axisPoint2); ^ lib/engine/rs_entity.h:477:18: note: overridden virtual function is here virtual void mirror(const RS_Vector& axisPoint1, const RS_Vector& axisPoint2) = 0; ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:128:18: warning: 'draw' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void draw(RS_Painter* /*painter*/, RS_GraphicView* /*view*/, ^ lib/engine/rs_entity.h:507:18: note: overridden virtual function is here virtual void draw(RS_Painter* painter, RS_GraphicView* view, ^ In file included from lib/engine/rs_arc.cpp:31: lib/engine/rs_constructionline.h:134:18: warning: 'calculateBorders' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void calculateBorders(); ^ lib/engine/rs_entity.h:520:18: note: overridden virtual function is here virtual void calculateBorders() = 0; ^ In file included from lib/engine/rs_block.cpp:28: In file included from lib/engine/rs_block.h:31: lib/engine/rs_document.h:65:18: warning: 'isDocument' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual bool isDocument() const { ^ lib/engine/rs_entity.h:187:18: note: overridden virtual function is here virtual bool isDocument() const { ^ In file included from lib/engine/rs_block.cpp:28: In file included from lib/engine/rs_block.h:31: lib/engine/rs_document.h:73:18: warning: 'removeUndoable' overrides a member function but is not marked 'override' [-Winconsistent-missing-override] virtual void removeUndoable(RS_Undoable* u) { ^ lib/engine/rs_undo.h:68:18: note: overridden virtual function is here virtual void removeUndoable(RS_Undoable* u) = 0; ^ 2 warnings generated. 17 warnings generated. make[1]: *** [sub-src-make_first] Error 2 make: *** [sub-librecad-make_first-ordered] Error 2 |
This looks like an issue with Qt.
What is the output of: qmake --versionHave you multiple Qt versions installed?
