Welcome @barfalloverme!
A first try could be to use latest LibreCAD version 2.2.0-rc4-23-ge3fae3dc. it is in release candidate state and safe to use.
Find it here:
https://github.com/LibreCAD/LibreCAD/releases/tag/latestThere is a known issue in latest version, with nested blocks, which are not loaded correct.
So this may be a dealbreaker for now. With nested blocks I mean blocks containing blocks.
Generally, this sounds like there is a real bunch of entities involved.
This is probably not a matter of RAM, but LibreCAD's capabilities to handle big files.
Its organization of entities is not optimal and it is known to become really slow with big files, but I never heard about crashes with big files.
Concerning copy/paste, this should usually work. Maybe you missed to set a reference point after copy command? Then paste does nothing.
- use COPY command
- set reference point
- switch to other drawing
- use PASTE command
- set insert point
AutoCAD should be able to open LibreCAD DXF files, but I can't test this.
I remember warnings from Autodesk TrueView, that LibreCAD DXF files are not created with AutoCAD, but iirc, they are opened.
