circle dimension text in inches
7 messages Options
matt
Hello all,
I'm new to LibreCAD (and pretty excited), but ran into an issue immediately.
I set up the default to be inches, then drew a 2" radius circle. when I try to dimension this part, I see no text. If I set my unit to mm and redraw the part (50mm radius), then dimension it shows up fine.
I'm guessing this is a default text size issue? Is there a way to fix this?
Thanks
Re: circle dimension text in inches
Can you share a test case dxf file to show this issue? Using the tool box ( More -> Upload a file )
matt wrote
Hello all,
Thanks
matt
no_dim_inches.dxf
here is a file showing the issue
buzz
I went to Edit -> Current Drawing Preferences -> Dimensions and set the
"General Factor" to 1. The diameter now shows up as 4.
Cheers,
Buzz
Buzz
matt
Cheers,
Buzz
Thanks, this works for me.
Question: it just shows "4"
How can I make it show 4.000 or 4.00 ?
buzz
I'm not sure about that one.
I found you can set the unit precision in Edit -> Current Drawing
Preferences -> Units, but it will not display trailing zero's. i.e. it
will display 1.4352 if that's the diameter of the circle but I can't
make it display 1.0000?
Cheers
Buzz
Buzz
Do you mean you want it to display "1.0000", you get "1"
If so, just upgrade your LibreCAD to the latest release (2.0.7)
Cheers
Buzz
