compiling with Qt Creator on windows
unimatrixdoc
http://librecad.org/cms/home/from-source/windows.html
Following the steps on the above page I ran into
 some compile error/warnings. The page said to
 report any issues with compiling.
Background:
Personally, I would prefer to stick with Linux but
 I would like to have some windows users (Vista/7)
 be able to view and toggle visibility of layers/blocks
 to print. Nothing I'm doing is mission critical, just for
 fun and as a hobby. Specifically, putting my entire
 property and structures/features in CAD. There is
 just a coolness factor to it all. I've come to the
 conclusion that having the latest/freshest build of
 LibreCAD is very nice so I've taken up the endevor
 to compile it myself. IT/Comp Sci background, use
 C++ mostly.
Using Git Bash:
$ cd Desktop/LibreCAD/
user@BOX ~/Desktop/LibreCAD (master)
$ date
Thu Feb 14 03:27:34 PST 2013
$ git pull origin master
From git://github.com/LibreCAD/LibreCAD
 * branch            master     -> FETCH_HEAD
Already up-to-date.
Errors:
(3-errors) error(message) requires one argument.  src.pro 862
C2466: cannot allocate an array of constant size 0  drw_cptable932.h 16
C2466: cannot allocate an array of constant size 0  drw_cptable949.h 13
C2466: cannot allocate an array of constant size 0  drw_cptable950.h 13
71 "Issues":
03:55:21: Running steps for project librecad...
03:55:21: Configuration unchanged, skipping qmake step.
03:55:21: Starting: "C:\Qt\Qt5.0.1\Tools\QtCreator\bin\jom.exe"
        cd libraries\ && ( if not exist Makefile C:\Qt\Qt5.0.1\5.0.1\msvc2010\bin\qmake.exe C:\Users\jonathan\Desktop\LibreCAD\libraries\libraries.pro -spec win32-msvc2010 -o Makefile ) && C:\Qt\Qt5.0.1\Tools\QtCreator\bin\jom.exe -f Makefile
        cd libdxfrw\ && ( if not exist Makefile C:\Qt\Qt5.0.1\5.0.1\msvc2010\bin\qmake.exe C:\Users\jonathan\Desktop\LibreCAD\libraries\libdxfrw\libdxfrw.pro -spec win32-msvc2010 -o Makefile ) && C:\Qt\Qt5.0.1\Tools\QtCreator\bin\jom.exe -f Makefile
        C:\Qt\Qt5.0.1\Tools\QtCreator\bin\jom.exe -f Makefile.Release
        cl -c -nologo -Zm200 -Zc:wchar_t -U__STRICT_ANSI__ -std=c++0x -O2 -MD -W3 -w34100 -w34189 -GR -EHsc -DUNICODE -DWIN32 -DEMU_C99 -D_USE_MATH_DEFINES -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_OPENGL_ES_2 -DQT_OPENGL_ES_2_ANGLE -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtSvg" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtWidgets" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtGui" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtCore" -I"..\..\generated\lib\libdxfrw\moc" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\mkspecs\win32-msvc2010" -Fo..\..\generated\lib\libdxfrw\obj\ @C:\Users\jonathan\AppData\Local\Temp\libdxfrw.obj.6068.15.jom
cl : Command line warning D9002 : ignoring unknown option '-std=c++0x'
libdxfrw.cpp
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(570) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(620) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(708) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(709) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(838) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(1114) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_entities.h(1115) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\dxfreader.h(41) : warning C4244: 'return' : conversion from 'unsigned __int64' to 'int', possible loss of data
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\dxfreader.h(42) : warning C4800: 'short' : forcing value to bool 'true' or 'false' (performance warning)
src\libdxfrw.cpp(152) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
        C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\INCLUDE\stdio.h(371) : see declaration of 'sprintf'
src\libdxfrw.cpp(185) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(221) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(261) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(301) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(383) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(894) : warning C4244: 'argument' : conversion from 'double' to 'int', possible loss of data
src\libdxfrw.cpp(906) : warning C4244: 'argument' : conversion from 'double' to 'int', possible loss of data
src\libdxfrw.cpp(1211) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1215) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1248) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1274) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1277) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1289) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1292) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1633) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1637) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
src\libdxfrw.cpp(1661) : warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
drw_entities.cpp
        cl -c -nologo -Zm200 -Zc:wchar_t -U__STRICT_ANSI__ -std=c++0x -O2 -MD -W3 -w34100 -w34189 -GR -EHsc -DUNICODE -DWIN32 -DEMU_C99 -D_USE_MATH_DEFINES -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_OPENGL_ES_2 -DQT_OPENGL_ES_2_ANGLE -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtSvg" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtWidgets" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtGui" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtCore" -I"..\..\generated\lib\libdxfrw\moc" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\mkspecs\win32-msvc2010" -Fo..\..\generated\lib\libdxfrw\obj\ @C:\Users\jonathan\AppData\Local\Temp\dxfreader.obj.6068.15.jom
dxfreader.cpp
dxfwriter.cpp
src\dxfwriter.cpp(185) : warning C4244: '=' : conversion from 'unsigned __int64' to 'char', possible loss of data
src\dxfwriter.cpp(186) : warning C4244: '=' : conversion from 'unsigned __int64' to 'char', possible loss of data
src\dxfwriter.cpp(187) : warning C4244: '=' : conversion from 'unsigned __int64' to 'char', possible loss of data
src\dxfwriter.cpp(188) : warning C4244: '=' : conversion from 'unsigned __int64' to 'char', possible loss of data
src\dxfwriter.cpp(189) : warning C4244: '=' : conversion from 'unsigned __int64' to 'char', possible loss of data
src\dxfwriter.cpp(190) : warning C4244: '=' : conversion from 'unsigned __int64' to 'char', possible loss of data
src\dxfwriter.cpp(269) : warning C4244: 'initializing' : conversion from 'std::streamsize' to 'int', possible loss of data
Generating Code...
src\drw_entities.cpp(203) : warning C4244: 'initializing' : conversion from 'double' to 'int', possible loss of data
src\drw_entities.cpp(268) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
Generating Code...
        cl -c -nologo -Zm200 -Zc:wchar_t -U__STRICT_ANSI__ -std=c++0x -O2 -MD -W3 -w34100 -w34189 -GR -EHsc -DUNICODE -DWIN32 -DEMU_C99 -D_USE_MATH_DEFINES -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_OPENGL_ES_2 -DQT_OPENGL_ES_2_ANGLE -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtSvg" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtWidgets" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtGui" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\include\QtCore" -I"..\..\generated\lib\libdxfrw\moc" -I"..\..\..\..\..\..\Qt\Qt5.0.1\5.0.1\msvc2010\mkspecs\win32-msvc2010" -Fo..\..\generated\lib\libdxfrw\obj\ @C:\Users\jonathan\AppData\Local\Temp\drw_objects.obj.6068.15.jom
drw_objects.cpp
drw_textcodec.cpp
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_cptable932.h(16) : error C2466: cannot allocate an array of constant size 0
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_cptable949.h(13) : error C2466: cannot allocate an array of constant size 0
c:\users\jonathan\desktop\librecad\libraries\libdxfrw\src\drw_cptable950.h(13) : error C2466: cannot allocate an array of constant size 0
Generating Code...
jom: C:\Users\jonathan\Desktop\LibreCAD\libraries\libdxfrw\Makefile.Release [..\..\generated\lib\libdxfrw\obj\drw_objects.obj] Error 2
jom: C:\Users\jonathan\Desktop\LibreCAD\libraries\libdxfrw\Makefile [release] Error 2
jom: C:\Users\jonathan\Desktop\LibreCAD\libraries\Makefile [sub-libdxfrw-make_first] Error 2
jom: C:\Users\jonathan\Desktop\LibreCAD\Makefile [sub-libraries-make_first-ordered] Error 2
03:55:25: The process "C:\Qt\Qt5.0.1\Tools\QtCreator\bin\jom.exe" exited with code 2.
Error while building/deploying project librecad (kit: Desktop Qt 5.0.1 MSVC2010 32bit)
When executing step 'Make'
Re: compiling with Qt Creator on windows
unimatrixdoc
Additional Information:
Built on Microsoft Vista 64bit Ultimate SP2
Qt 5.0.1 for Windows 32-bit (VS 2010, 481 MB)
Qt Creator 2.6.2 (based on Qt 5.0.1 32bit)
Built on Jan 30 2013 at 7:08:53
From revision 55e2124f32
Microsoft Visual Studio 2010
Version 10.0.30319.1 RTMRel
Microsoft .NET Framework
Version 4.0.30319 RTMRel
Installed Version: VC Express
Microsoft Visual C++ 2010
To build LibreCAD in windows is required "Qt libraries 4.8.4 for Windows (minGW 4.4, 317 MB)"
version 5 do not work (at the moment)
I made some patches in source code to remove yours compiler error and many of the issues.
To build LibreCAD on windows read this:
https://github.com/LibreCAD/LibreCAD/blob/master/README.md
Prerequisites are boost & and Qt 4.7.x or 4.8.x
Qt 5.0.x are very recent and not supported at the moment.
About compiler Mingw are supported Visual C++ are not tested and you can found more errors and issues.
If you want, you can send patches to:
http://sourceforge.net/tracker/?group_id=342582&atid=1433846
or
If you just want a more updated version (2013-01-28) you can found in this thread:
http://forum.librecad.org/download-master-branch-precompiled-binaries-td5707583.html
